Results 1 to 15 of 24
    Default CLONING SID 208 ON A FORD TRANSIT
    Hi I need to clone a SID 208 on a FORD TRANSIT 2011 model.
    Ori ecu has water damage but still alive, and I have read it with ktag already .I am willing to pay for a working solution.
    Thank you.
    jakesman's Avatar
    Oct 2013
    Bethlehem Southafrica
    not expert here on this ecu but is it not like most ecu , swap eeprom and flash , and u are good to go ?
    Sent from my HUAWEI Y560-L01 using Tapatalk
    Ask a dumb question and become wise for the rest of your life, but act wise and stay dumb
  3. The Following User Says Thank You to jakesman For This Useful Post:
    PAVLOS2 (26th September, 2018)
    Quote Originally Posted by jakesman View Post
    No it’s not at like that at all ,It’s a tricore with no external flash and unique data for each ecu that need some trick to be done .Iknow there are people that can do it so that’s what I’m asking to learn.
    jakesman's Avatar
    Oct 2013
    OK , now I will learn also , have been off the grid for about 2 years , thing have changed
    Mar 2013
    Europe
    Few Months ago have Customer with same problem with SID208 Ford Transit 2010 or 2011
    He buy ssecond hand ecu with same Partnumber and i cloned ECU.
    Read old data and write complete to new "second hand ECU"
    For ma was working fine with Ktag ;-)
  7. The Following User Says Thank You to bersch8688 For This Useful Post:
  8. #6
    Sep 2018
    With MPPS v18 by OBD U can read\write full flash, swap or clone eeprom
  9. The Following User Says Thank You to mlody48321 For This Useful Post:
  10. #7
    Quote Originally Posted by bersch8688 View Post
    Did it with Ktag and all ok!!!! some times we sould not read so much about ( what and how before trying)
    Thanks again
  11. #8
    Mar 2015
    UA
    Hey. Now give this ECU to your colleague, let him try to read it with his equipment. No one else will read this ECU. So wrong.
  12. #9
    Quote Originally Posted by MVVL View Post
    Ok I see would you like to explain what is so wrong about it and why its so diffrent from others ? I think thats why we all write here correct ?
  13. #10
    rola1971's Avatar
    Jun 2014
    Dublin
    Quote Originally Posted by PAVLOS2 View Post
    avdi orginal it proggraming to you car
    i try cloning used Magprog x17 but it is dont work
  14. #11
    Mar 2015
    UA
    Hey. For cloning of such blocks I use a pcmflasher, for it I have an instruction. You can also do this procedure, but if you do it like that, then no one else except you can read this block-write. If you do it right, you need to transfer the password from the original ECU to the donor's flush.
    Try to install the program Ktag on another computer and read this ECU.
  15. The Following User Says Thank You to MVVL For This Useful Post:
    PAVLOS2 (27th September, 2018)
  16. #12
    Ok !!! thank you for the information (every day we learn something new )
  17. #13
    Sid 208 Transit
    I did clona and no problem
  18. #14
    Quote Originally Posted by ciekawy View Post
    Sid 208 Transit
    Yes cloned with ktag tc1797 and eprom from ori ecu and car worked fine.
  19. The Following 2 Users Say Thank You to PAVLOS2 For This Useful Post:
    maybach_ (29th August, 2019), VVDI (27th September, 2019)
  20. #15
    bursuc's Avatar
    Oct 2011
    inside MCU
    Hi, maybe somebody can help me with this problem
    I have 2 ford transit 2014 ecu SID 208
    one of my friends try to clone this ecu wih China Ktag but he was not able to start the car after cloning. All went ok when reading original and writing into donor ecu bur car NOT starting
    He send the ecu to me to try wih different machine VF2 flasher or EU 7.020 KTAG.
    But donor ecu has been already written and now i am not able to read or write it anymore.
    There is any solution to this?
    Should i try different tool?
    Error message is regarding
    MICRO PROTECTION FAILED
    Any advice, much appreciated.
    Dosen't matter how hard is to repair something as long is made by humans and thinked by humans !
