Hi everyone!
Your help needed!
Crash
Peugeot 508, 2012
Airbag module 9677910680, Continental
EEPROM 95640
Thanks in advance!
Hi everyone!
Your help needed!
Crash
Peugeot 508, 2012
EEPROM 95640
Thanks in advance!
hi
try............
Your cleared tested file ...
Hi, can you plz resend password? I keep getting message about wrong checksum..
Update
I keep getting an error B1003 - Secure configuration fault (Absence of calibration). I wasn't able to open the file from diagprog so I don't know if it was good or not. I got the same file as from goblincalm from various sources, free and paid ones and I generated exactly the same file myself and some of my fellows who know more than me told me that it can be a hardware fault. So, I've ordered a replacement ECU. Today it arrived, and guess what? Right! The same B1003! Now I'm really stuck and beg for help!
What scan tool are you using? obviously you have a calibration fault, someone with PeugeotPlanet scanner can calibrate it for you.
Don't Forget to Rep + Thanks If I helped you
Diagbox, Launch, Abrites. I'll ask about Peugeot Planet.
There are some calibration data somewhere in the dump an it's gone while clearing. It would be great to find where.
Open the cleared crash file and check on line 400-410 if the vin number is present. i cannot access your cleared files since they have a password.
Thanks for your reply, yes indeed the correct VIN is in every file I've tried
I mean, I got 6 identical files from various sources, which are like goblincalm sent me (it has no password). They are modified the same way.
The software i use made a very slight modification comparing to the file that goblincalm sent you. give it a try if you want.
Any news?...
try and report, must work....
if not work you have an hardware problem, or other problem on the car friend....
this file was tested on car by me.
BR
mikedmirjian, Unfortunately, it didn't work also..
Safetybags, thank you, I gonna try this right away!
