Results 1 to 13 of 13
    Aug 2018
    Russian Federation
    Default KTAG 7.020 Repair?
    Good afternoon!
    Now I connected my KTAG 7.020 declared as EU Clone.
    KSUITE 2.23 Net Safe. All completely gray, in the INFO tab all lack of. Help solve the problem!
    Previously everything worked fine
    Jun 2013
    EU
    Open it and clean sd card and sd card slot, refit sd and try again with ksuite.
    Aug 2018
    Russian Federation
    Quote Originally Posted by morgano View Post
    but sd-card only for cid?
    Jun 2013
    EU
    Mate clean it with isopropyl alcohol, if processor on boot cannot read the SD you get that exact info screen.
    If ktag was working properly and suddenly stopped working try it.
    If scenario is different just explain.
    AVDigitale's Avatar
    Apr 2017
    Best Place in the World!
    this happens when you doing bad things for people what helped you !
    Proffesional ECU & TCU Tuning
    Petrol and Diesel Engines
    File Service
  6. The Following User Says Thank You to AVDigitale For This Useful Post:
    morgano (29th September, 2018)
    Jun 2013
    EU
    Quote Originally Posted by AVDigitale View Post
    Lol, i got lost with this answer, what do you mean?
    Jun 2013
    EU
    Quote Originally Posted by QuantumECU View Post
    This is only a problem if your original SD got dead.
    In that case you need a brand new sd, extract the cid from it and order a custom sd image for your new sd card CID. These china sd cards are shit, die very often, and only solution is what i said before. New sd, order custom image for it and done, ktag alive again.
    Aug 2018
    Russian Federation
    Thanks to his work, I got 1200 euro, he is angry with me now)))
  10. #9
    Aug 2018
    Russian Federation
    Changed the CID, downloaded the image of the SD card, but everything is as before
  11. #10
    Jun 2013
    EU
    Cid in sd and cid of image you downloaded match?
  12. #11
    Aug 2018
    Russian Federation
    Buy a new SD card;
    Change CID;
    Write IMG
  13. #12
    Jun 2013
    EU
    Buy a new SD card;
    Change CID;
    Write IMG
    So it was dead chinese sd
    You were lucky to find sd that allow CID changing nowadays.
  14. #13
    Aug 2018
    Russian Federation
    I repair this tool!
    1)Download files at SVVAG2000
    2)Download SD Card Formatter
    3)Old SD Card format in "overwrite format" and no label
    4)Download Win32DiskImager and write SD image !!!!2!!!! times (before the second time you can not format)
    5)Insert SD-card to KTAG and plug to notebook. Start KSUITE 2.23 and have fun!
  15. The Following User Says Thank You to QuantumECU For This Useful Post:
    prusony (9th September, 2019)
