Page 1 of 3 123 LastLast
Results 1 to 15 of 40
    castin's Avatar
    Oct 2015
    Default Astra H cd30 MP3 and GID "Display SAFE" on GID --SOLVED--
    Please, log out the radio and display. Display "SAFE" on the display all the time.
    Radio pin - 0050. Pin GID / CAR - 9397. I tried to log out the radio and log in again - no effect.
    There is another VIN in the UEC, both codes do not match. I've included screenshots.
    uec vin.JPGI do not have any ideas anymore.
    bank's Avatar
    Feb 2017
    Ukraine
    Use this dump for display to unmarry radio using code 0050.
    Then you can pair with any code
  3. The Following User Says Thank You to bank For This Useful Post:
    castin (28th September, 2018)
    bank's Avatar
    Feb 2017
    Ukraine
    Or use this dump for radio to pair with your display using code 9397
  5. The Following 2 Users Say Thank You to bank For This Useful Post:
    castin (28th September, 2018), geocity (9th February, 2022)
  6. #4
    WALES
    Quote Originally Posted by castin View Post
    Use this radio dump and pair using 9397
    wbr
  7. The Following User Says Thank You to shooting For This Useful Post:
  8. #5
    WALES
    Quote Originally Posted by bank View Post
    I do not think you understand these radio's very well.....
    wbr
  9. #6
    bank's Avatar
    Feb 2017
    Ukraine
    Quote Originally Posted by shooting View Post
    I don’t think so
    It’s all unmarried
  10. The Following User Says Thank You to bank For This Useful Post:
    kowalwalcz (29th September, 2018)
  11. #7
    WALES
    Proves nothing, I look at Post#2 & Post#3
    wbr
  12. #8
    castin's Avatar
    Oct 2015
    Progress is. Unfortunately, my OPCOM can not turn on the anti-theft lock.
    The radio makes a beep on the "radio safe" display.
    Is it possible to pair in a different way by modifying the eeprom?
  13. #9
    bank's Avatar
    Feb 2017
    Ukraine
    Check mid speed can bus parameters. It should be the same in DIS and EHU, and correct accoding to a car configuration.
    As example, ECC is disabled in can bus but present in car or vice-versa
  14. #10
    WALES
    Read Post#4
    wbr
  15. #11
    castin's Avatar
    Oct 2015
    Read Post#4
    wbr
    Im use Your file . But OPCOM sey succes, radio restart, but stil radio safe and beep.
    in measurement blocks radio status: delivery state.
  16. #12
    bank's Avatar
    Feb 2017
    Ukraine
    Because you have incorrect mid speed can bus config.
    You can see by reading DTC's
    Or, it can be Security wait time activated in display
  17. #13
    castin's Avatar
    Oct 2015
    Check mid config and is the same.
    Maybe the time lock in the display?
    Wait, im check now this time locked.
    Security Wait time in GID - In Progress
    What does it mean?
  18. #14
    bank's Avatar
    Feb 2017
    Ukraine
    C
    May be, after you were trying to deactivate radio
  19. #15
    castin's Avatar
    Oct 2015
    After i must Activate or Deactivate thief protection? I think now is deactivate and must be activated.
