    Oct 2015
    Default Opel Vivaro error configuration
    Hi, I haveerror B0003 configuration on Opel Vivaro after crash. Repaired airbag and pretensioners, no more DTC, only B0003 configuration. I think ORI file is not crash. Van only have driver airbag.
    Here is ORI file 95160
    dragon100's Avatar
    Jan 2012
    From land of milk and honey
    Check this ...
    Scripts for Multi-PROG
    Best regards.
    Dragon
  3. The Following 2 Users Say Thank You to dragon100 For This Useful Post:
    Perryking (3rd October, 2018), reproteq (24th January, 2019)
    reproteq's Avatar
    en algún lugar de España
    hi dragon100
    i have same ecu same problem
    can you share pass of your solution for compare
    thanks alot man
    reproteq's Avatar
    Quote Originally Posted by Perryking View Post
    Hi Perryking
    you solved problem?
    i have same error b0003
    can you share solution?
    Dec 2010
    Ukraine
    You can fix it by Renault Clip in SRS config menu.
    reproteq's Avatar
    i dont have this tool
    only op-com and avdi and i tried without succes
    you know if with other tool is posible.
    have you a good dump of ecu working?
    thanks man
