Results 1 to 5 of 5
    Sep 2018
    Default Alfa Romeo Brera 2.4jtdm
    Hello guys,
    I believe you can help.
    In attachment there are original and stage1 files for your databases.
    I already have stage1 in my car but this remaped file is done on 147KW version of the car.
    Now i replaced original turbo (KKK- 147KW version) for turbo from 154KW version(Garett)
    Swirl flaps physicaly aren't there, Egr blinded also DPF isn't physicaly there
    I would like more power now.also need turned off FLAPS,EGR,DPF
    Can somebody help with it?
    Car is mechanically OK
    HW: 0281013417
    SW: 1037390938
    Antonin159
    AVDigitale's Avatar
    Apr 2017
    Best Place in the World!
    you are new here and in all post you need help
    help first some other they somebody will help you
    Proffesional ECU & TCU Tuning
    Petrol and Diesel Engines
    File Service
    Sep 2018
    Quote Originally Posted by Antonin159 View Post
    Hello guys,
    HW: 0281013417
    SW: 1037390938
    Antonin159
    You know the high pressure pump is different. Check the injectors also because you would lean out.
    Sep 2018
    Ok, somebody can help, post some file? thx
    maajkii's Avatar
    Mar 2017
    Poland - Sława ( Lubuskie )
    no......... its all you want, file
    DSG TUNING
    File Service
