Page 3 of 3 FirstFirst 123
Results 31 to 44 of 44
  1. #31
    Apr 2016
    uk
    Turn it in lock position.
    The horn may not sound. In some vehicles will sound in some will not...
    Quote Originally Posted by mrnixdorf View Post
    Guys, i can't understand how the remote central locking works in Golf 4
    Is it related to the Autoradio???!! cuz it's an aftermarket radio mounted
    For the 00953 - interior light time limit 25-10 - unknown switch condition
    All the interior lights working just fine, when opening the doors, the light comes on for about 20 seconds then off, all bulbs are okay. but still got this error msg.
    Checked the fuse 14 & othes with multimeter all are ok.
    I wasn't able to program the key remote using vcds, on each time, i got an error message of "bad key programming"
    Even using those steps :
    1. Key in ignition, turned to ON (not started, just lights on dash)
    2. Doors, trunk, hood closed
    3. 2nd key in drivers door
    4. Turn door key to unlock position (counter clockwise) and hold approx 10 seconds until horn honks 3 times
    failure at step 4, the horn won't honks, nor does the whitebox ever click
    i would appreciate any suggestions.
    Inviato dal mio HTC 10 evo utilizzando Tapatalk
  2. #32
    Sep 2016
    GB
    I tried it, no success, in lock and unlock positions, driver and passenger door, nothing works, tried many manipulation, holding lock button 10 sec, and try 1 sec method, tried double click too, thr car isnt responding.
  3. #33
    Sep 2016
    GB
    I think its the autoradio wiring that cause the problem, will check and let you know
  4. #34
    Apr 2016
    uk
    I had same issue with a Polo. Because of the radio I couldn't connect to anything thru the obd..
    Also go to remote adaptation and check how many remotes were stored previously. Some golfs don't have option for remote control...
  5. The Following User Says Thank You to comizelu For This Useful Post:
    mrnixdorf (17th October, 2018)
  6. #35
    May 2016
    Kaunas
    With vcds check out the comfort module code. If it is 1J0 959 799 AH it supports the remote key. If 1J0 959 799 Q or 1J0 959 799 L it does not support remote keys.
  7. The Following User Says Thank You to vaicekas For This Useful Post:
  8. #36
    Sep 2016
    GB
    Thx guys i will check that
  9. #37
    Sep 2016
    GB
    Its 1J0 959 799 AH
    Seems a remote key problem, will try another one
  10. #38
    Jun 2013
    Please confirm that you have disconnected + cable on the battery 12V. For a short while.
    Just for a fresh start of the modules.
    Did you get a solution for the immo? Or is the main interest remote control
  11. The Following User Says Thank You to Weasel3 For This Useful Post:
    mrnixdorf (18th October, 2018)
  12. #39
    Sep 2016
    GB
    I will do that, for the immo its ok, it was the coil reader cable problem
    The only problem is the remote now.
    This is from where i bought the key https://fr.aliexpress.com/item/Car-R...832303505.html
  13. #40
    May 2016
    Kaunas
    This key is not valid. It is suitable for Škoda not VW.
  14. #41
    Sep 2016
    GB
    Sorry my mistake, this is the link https://fr.aliexpress.com/item/Car-R...220ea7795dc13c
  15. #42
    Jun 2013
    1J0959753 N - Would probably get you out of this headache.
    Maybe you can call your VAG dealer, to confirm the part number fitting the vehicle.
    Order one locally in EU this evening. And you should solve this by Monday.
    Or maybe tomorrow, if you can get one from your local pro Locksmith.
  16. #43
    Sep 2020
    Can I program a 1JO 959 753 CT 434mhz remote to a Golf 4 2000 year with a original remote 1JO 959 753 A 433mhz. Is it going to work because of the diference between 433 and 434 mhz?
  17. #44
    Oct 2013
    Serbia,Mladenovac
    Od you jave lock on passanger door,you not have remote centrale
    Послато са Nokia 3.1 Plus помоћу Тапатока
