Results 1 to 11 of 11
    yugo45's Avatar
    Default EFfi and Mercedes key
    Does anyone know it is EFfI with Zedbull mini can generate key for Mercedes with HC05 like W140, W202, with Immo box and HC05?
    I see it has Image generator , and want to know how that works.
    Thanks in advance
    droidwayne65's Avatar
    Aug 2015
    North America
    Quote Originally Posted by yugo45 View Post
    Thanks in advance
    It generates key files that look identical to the ones I've read from dealer keys and those generated by Tango. I assume they work the same although I've never actually written one to a key. I use the files generated by the AK500 Old Remote Key feature, which I strongly suspect is actually a Gambit programmer.
  3. The Following User Says Thank You to droidwayne65 For This Useful Post:
    yugo45 (11th October, 2018)
    szengen's Avatar
    Jan 2017
    Effi a clase not ok,Gambit a clase Ok.
    fang, Narwalus microcephalus,Spectrum Zx, Atari amiga, Commodore +4
  5. The Following 3 Users Say Thank You to szengen For This Useful Post:
    doctore (11th October, 2018), klesk1986 (10th October, 2018), yugo45 (11th October, 2018)
  6. #4
    yugo45's Avatar
    Quote Originally Posted by szengen View Post
    What about S class, SL class, C class, ML?
    lion0304's Avatar
    Oct 2014
    ML did several with Gambit, no problem.
  8. The Following User Says Thank You to lion0304 For This Useful Post:
    doctore (12th October, 2018)
  9. #6
    doctore's Avatar
    Nov 2015
    Colorado Denver
    Also fvdi 2014 can duet ml on obd tested
    also i bay this but newer tested
    Professional bmw key service cas 3/3+ 4/4+ repair = reset ews egs 8hp = 6hp-egs19d
  10. The Following 2 Users Say Thank You to doctore For This Useful Post:
    mexanico1971 (12th October, 2018), yugo45 (12th October, 2018)
  11. #7
    yugo45's Avatar
    Quote Originally Posted by lion0304 View Post
    Sorry I should be more clear,
    I was asking about EFfI for those models?
  12. #8
    Oct 2015
    efi not work at A class, gambit working older models without white sticker well, with white sticker 5WK4 no way.
    6841707059 576F526B 57416E5453 596F55 526F6B69424152
  13. #9
    yugo45's Avatar
    Ok let me get this clear,I do not need Info for Gambit, I need info for EFfI.
    Anyone knows how EFfI works with old W140 S-Class,SL-Class, W202 C-Class,ML?
  14. #10
    Hello Mate,
    1) ML:
    EFfi has no software for that use Gambit and others...
    2) W140 S-Class,SL-Class, W202 C-Class with two LEDs (Red and Green) at the interior Driven Mirror, Chipless remote:
    Effi software 122 can Generate Remote file for the 93c4 in the remote PCB from the HC05 dump.
    3) W140 S-Class,SL-Class, W202 C-Class with transponder chip in the Remote flip key :
    EFfi does not support this use another tool such as GAMBITequally in some cases no need read the dump from HC05 , just generate a self learning transponder using TANGO or Tmpro2 software 148 and blank PCF7935AS.EFfi also have this function in its Image Generator Menu but never tested it.
    Best Regards
  15. The Following User Says Thank You to ngakson2002 For This Useful Post:
    HeXeN (17th October, 2018)
  16. #11
    yugo45's Avatar
    Quote Originally Posted by ngakson2002 View Post
    Hello Mate,
    Best Regards
    This is what I need feed back if anyone test it , Generate tranposnder 7935 , I do not need remote stuff???
    Thank you
