Results 1 to 15 of 15
    sasy90's Avatar
    Italy
    Default Tool to mod mileage Renault Kadjar 2017
    Hi to all,
    I need to ask if someone have a positive feedback to mod km in Renault Kadjar 2017/ Megane IV / Dacia Lodgy 2017 .
    I need to say what tool can do it and if someone have already done this car.
    So in dashboard and in ABS module.
    Thanks in advance
    Jun 2019
    Default Any tool?
    Quote Originally Posted by sasy90 View Post
    Hi to all,
    Thanks in advance
    Hi @sasy90, did you get any tool for a Kadjar 2017?
    Thanks!
    t77's Avatar
    Poland Lodz
    Hello see this www.smok.com.pl renault licence RT 0021 with ABS km mod
    sasy90's Avatar
    Italy
    Only abrites with ams active can do this car....
    TOINO's Avatar
    Jan 2012
    yes with smok already done talisman 2016 dash and abs everything ok
    smok in the first time does dash flash and then writes abs
    I commented with clip reading miles on the abs and was successful miles on the abs changed!
    brend's Avatar
    Oct 2015
    Same where
    Smok very well for Renault Kadjar 2017/ Megane IV / Dacia Lodgy 2017 !......................biker.gif
    Aug 2016
    EURO-KOLCHOZ
    also x-tool
    centrohifi's Avatar
    Apr 2011
    From Italy .......
    tried now with Smok ... 440Euro of module, I have error "Read FLS ERROR"
    does not work.
    Try to contact support, little hope, to have a solution !!!
    ..Ecu Repair ... Steering Wheel Repair ... Dash Repair ... AirBag Repair .... that Bad LiFe ...
    Jun 2018
    London
    Hi.
    Did you check Visteon or Continental dash first with CAN Clip before ?
    Is the dash dead after your work ?
    Quote Originally Posted by centrohifi View Post
    does not work.
    DK Veteran kams20040's Avatar
    Quote Originally Posted by TOINO View Post
    So what to do in first .... abs or dash????
    Team dz's Avatar
    Apr 2017
    ALGERIA
    X-TOOL WORK PERFECT ! 20 minite
    dach+abs
    DPF / FAP / EGR / SCR / NOx / TVA FLAP .. etc
    Do not forget to press the button thanks and reputation
    # Algerian #
  12. The Following 2 Users Say Thank You to Team dz For This Useful Post:
    rtbdiagnostic (4th November, 2019), sentini (9th June, 2021)
  13. #12
    brend's Avatar
    Oct 2015
    Same where
    Need just know how work with this!!!!
    Error because modul after 3 min always try go slip mode and after 2 min turn power off.
    Just need 3min interval pash start button and no problem with read flash from this car.
    does not work.
  14. #13
    Jan 2017
    hi mate, what is the procedure with x-tool i have a kadjar with visteon instrument cluster to change parameters
    thanks in advance
  15. #14
    marina_rv's Avatar
    Ukraine
    write km in dash + ABS -- work tested.
    please press the little THANKS
  16. #15
    Feb 2019
    Hungary
    Hello.What type is xtool?
