Page 1 of 4 1234 LastLast
Results 1 to 15 of 50
    BusCan's Avatar
    Nov 2013
    Default Dump and pin For BCM Opel Meriva 70F3380
    Hello
    Following a bad handling of a programmer I mistakenly erased a Pros 70F3380
    BCM 13356921
    If a person who has a dump with pin code it will be super cool
    I enclose a photo of the module with pinout
    Thank you
  2. The Following 7 Users Say Thank You to BusCan For This Useful Post:
    alclot (3rd December, 2019), AlexDi (4th March, 2023), bendy (12th October, 2021), eleeinidis (14th September, 2022), marouanos (25th October, 2022), plamen 63 (23rd August, 2020), pvovo (18th November, 2022)
  3. #2
    BusCan's Avatar
    Nov 2013
    Default pin code Opel
    Possible to help me code securité for the dump
  4. The Following User Says Thank You to BusCan For This Useful Post:
    ecuauto (21st November, 2021)
  5. #3
    Bllinda's Avatar
    Baltic
    try. .... ....
    today
    A topic that interests me
  6. The Following User Says Thank You to Bllinda For This Useful Post:
    BusCan (17th October, 2018)
  7. #4
    BusCan's Avatar
    Nov 2013
    Thanks Bllinda
    I am looking for a Flash and Flash dump for this module BCM 13356921 uPD70F3378
    If any of you have this, it's so cool
    Thank you
  8. #5
    BusCan's Avatar
    Nov 2013
    Possible to give me a pin code from the VIN?
    I can not read the MCU 70F3380 it and protect
    Here is the wine W0LSD9ECXB4260985
    Thank you for your help I am stuck with this car
  9. #6
    Bllinda's Avatar
    Baltic
    read the device data that has this vin code
    Quote Originally Posted by BusCan View Post
    today
  10. The Following User Says Thank You to Bllinda For This Useful Post:
    zoko (23rd March, 2022)
  11. #7
    BusCan's Avatar
    Nov 2013
    Quote Originally Posted by Bllinda View Post
    Hi Bllinda
    Not possible this MCU and protected
    Readings : disabled
    Programming : enabled
    Block Erasing : disabled
    Boot ReWr : enabled
    Chip Erase : enabled
  12. #8
    BusCan's Avatar
    Nov 2013
    try. .... ....
    Hi Bllinda
    Your code not good code Upside down!! after 3 days of work and purchase of Smok
    Thank you
  13. #9
    BusCan's Avatar
    Nov 2013
    Her read NEC 70F3380 For Meriva B 2011
    BCM 13356921
    Reading via IoTerminal
    Code 2503 for reset
    if it can help someone other than me
    Good luck
  14. The Following 6 Users Say Thank You to BusCan For This Useful Post:
    bendy (12th October, 2021), COTECH 81 (9th November, 2020), miroopel (7th October, 2020), nemena (18th October, 2021), Nikola1309 (4th February, 2022), subas (8th February, 2024)
  15. #10
    BusCan's Avatar
    Nov 2013
    Hello everyone
    A person knows the key programming procedure for Opel Meriva B year 2011
    I have a professional OP-Com a days
    I enter into dialogue with the BCM Reset my impossible to recognize the keys
    If someone between you know the procedure it will be super cool
    Thank you
  16. The Following User Says Thank You to BusCan For This Useful Post:
  17. #11
    BusCan's Avatar
    Nov 2013
    Hello everyone,
    After a hard research on the CBM system I finally modify a dump (Dflash) on a BCM
    I spent them in a Total Virgin operational with GM_MDI
    If someone is stuck with this source he asks me
    It's free just a thank you me enough
    And thanks to our friend Bllinda
  18. The Following 9 Users Say Thank You to BusCan For This Useful Post:
    AlexDi (4th March, 2023), calit10 (29th October, 2023), COTECH 81 (9th November, 2020), jomberykaso (26th March, 2019), kobelco (18th November, 2022), nemena (18th October, 2021), Nikola1309 (4th February, 2022), publiperro (17th December, 2020), zoko (23rd March, 2022)
  19. #12
    Sep 2015
    France / midi-pyr?en?es
    Bonjour je serais intéressé par le Dflash le problème je ne trouve pas que l'eeprom est le MCU UDP70F3380 que ce soit avec le prog vvdi ou upa usb j'ai un message d'erreur l'eeprom est protégé avez-vous une idée merci
  20. #13
    Sep 2015
  21. #14
    Sep 2015
    hello l would be interested in the Dflash the problem l do not find the eeprom is the UDP70F3380 whether with the vvdi or upa usb prog l have an error message the eeprom is protected have you any idéa thank you
  22. #15
    publiperro's Avatar
    Apr 2016
    España
    Hello everyone,
    the car is in transport mode and there is no way to get it out that way.
    bcm used micro 70f3633 / 70f3634I bought used bcm and I try to program with opel tips after having virginized it with the io / terminal option, but it fails in the programming, I want to think that it is because the number of the vin is not the same, there is a way to change it.
    here is the dumps of the original bcm of the car with transport mode and the used one that is fine.
  23. The Following User Says Thank You to publiperro For This Useful Post:
    wojtech (26th April, 2023)
