Results 1 to 12 of 12
    Portugal
    Default Megane MK3 UPC diagram
    Hi have a big problem with Renault Megane 3 2013 with Start Stop, in upc 284B62069R módule. I swap this módule 3 times and i have same error. DTC 921114, and i ave allwais 15,91 V from batery. I test batery and i have 12,2V and 14,2 V after start. Someone have a diagram from this módule. I need find some broken wire. Thanks.
    Portugal
    No one can help?
    Louislesinge's Avatar
    Jun 2017
    French Jungle
    Here:
    Be carefull, there are 2 kinds of UPC, and many kinds of engines. Alternator is 103, of course.
    Greetings,
  4. The Following 8 Users Say Thank You to Louislesinge For This Useful Post:
    boxsport (4th January, 2025), cheaper (11th November, 2024), Col19 (12th November, 2023), Galfro (31st July, 2024), jolor (21st October, 2018), mexanico1971 (22nd March, 2020), paskuale (16th November, 2018), TeiS (23rd June, 2023)
    Bratislava,Slovakia
    Quote Originally Posted by jolor View Post
    Hi.
    I same problem.
    What is the solution friend?
    rafal's Avatar
    UK - PL
    check wiring of upc
    need help
    now my goal is to buy xp-005
    who will help?
    gomarota's Avatar
    im having same problem and i found one broken wire from upc to batery disconnection module, now the voltage is fine, but engine light is on dashboard and after som start and stop it says dtc about permanent supply upc, i changed 2 upcs anyone know what can be problem?
    LOVE DK!
    Oct 2018
    hola, ¿revisaste la caja de desconexión de la batería del fusible f7?
    i, ¿comprobó la caja de desconexión de la batería del fusible f7?
    Feb 2021
    Chaves, Portugal
    I'm having the same problem with a car whose alternator was charging at almost 16V.
    Tried two different UPC's and the issue remains, cables seem fine...
  10. #9
    rafal's Avatar
    UK - PL
    Quote Originally Posted by Pascaleiro View Post
    Looks like voltage regulator bricked
    need help
    who will help?
  11. #10
    Feb 2021
    Chaves, Portugal
    Quote Originally Posted by rafal View Post
    Client brought two used alternators, didn't solve anything, we ordered a new one and charges fine, but there's always an error.
    Autel: DF051
    Bosch or Texa: B1211
    It's the same error but different codes. All tell something like "UPC voltage supply control unit - open circuit/ground short"
    I was trying to access those files from Louislesinge but don't seem to have permission
    EDIT:
    I can access them now!
  12. #11
    Feb 2021
    Chaves, Portugal
    Cool
    Solved the problem!
    Diagnostic software read a stuck battery voltage at 15.94V from battery, other values were the usual fluctuating 12V or 14V.
    From the diagram I knew it had to be the red BP1C wire, and it had a bad connection behind the headlight, already had been soldered before, and the wire was too stiff, looking as if it was in contact with water.
    Thanks!
  13. The Following 4 Users Say Thank You to Pascaleiro For This Useful Post:
    Col19 (12th November, 2023), ghostryder23 (25th September, 2023), harrisrigg (9th September, 2024), LacoBL (24th November, 2022)
  14. #12
    PierreTheron's Avatar
    Centurion,South Africa
    in my case it was the 5amp fuse on the side of the battery disconnect unit for the BP1C wire.
    https://www.youtube.com/watch?v=Q4ue...nnel=RobOxlade
  15. The Following 2 Users Say Thank You to PierreTheron For This Useful Post:
    kronk92 (13th November, 2024), rsilva (17th April, 2025)
