Results 1 to 8 of 8
    Default Audi TT Dash 2004.
    Vehicle Details
    Audi TT 2004 non quattro 180 BHP
    Hi all I got a Audi tt 2004 magnet mirelli MM22 Instrument cluster that required changing a replacement used cluster has been purchased I have fitted to car but the centre display is pix-elated. I have had the ribbon cable display and stepper motors for fuel and temp and fitted to car repaired. And have tried with Avdi (Original) and VVDI 2 to adjust mileage so is correct with the original but each time it says can not find mileage and no pin displayed. So I have a friend with a 2002 Audi tt I went to read his dash and the same could not find mileage or pin?(Dumps attached) I know these cluster are shit and have problems with micros ect. Also the fuel gauge is working the opposite way and also intermittent (Have read this could be due to a early sender being fitted to a later car).Sender unit part no 8L0 919 051 N fitted. I have done needle sweep test with vcds and all looks good. Does Anybody have any advice or dumps for this dash? Part No. 8N2 209 90A MM22 MM4?
    brend's Avatar
    Oct 2015
    Same where
    Need read in bench bdm away.
  3. The Following User Says Thank You to brend For This Useful Post:
    Galee (24th October, 2018)
    dominik.m's Avatar
    Jun 2009
    POLAND
    Hi. Read HC912 on bench and upload file.
  5. The Following User Says Thank You to dominik.m For This Useful Post:
  6. #4
    Aug 2018
    Read dash by programmer 912DG128 your files are only partial read.
  7. The Following 2 Users Say Thank You to TFSIQuattro23 For This Useful Post:
    Galee (24th October, 2018), karl Martin (10th March, 2021)
  8. #5
    Thank you all and thanks to you TFSIQuattro23 for the photo.
  9. #6
    Sorry to drag up a old thread I’m trying to read a 2002 tt dash 912dg128 mask 3K19D with ori Usb UPA with above connection but am having no luck.IMG_8027.jpgYou_Doodle_2019-11-21T16_49_49Z.jpg
  10. #7
    jomberykaso's Avatar
    Sep 2013
    En algun lugar de Chile
  11. The Following User Says Thank You to jomberykaso For This Useful Post:
    Galee (21st November, 2019)
  12. #8
    That’s what I have.
