Results 1 to 11 of 11
    figani's Avatar
    Feb 2018
    47 45 52 4D 41 4E 59
    Default PSA Peugeot 508 EDC17CP42 Additiv P15B3
    hi....
    we have Peugeot 508SW 2012.... EDC17 CP 42...
    additiv level low P15B3...
    with diagbox not possible to delete fault code...
    yes, we filled it up with additiv...
    also under the other groups in diagbox related to additiv container...
    it ends every time with comunication failure...
    does someone have a solution?
    Dec 2013
    yes I have solution for this
    DPF/FAP off, AdBlue off, EGR off, Throttle valve off, Flaps off, DTCs off, Lambda off,
  3. The Following User Says Thank You to gitko For This Useful Post:
    figani (26th October, 2018)
    immokill's Avatar
    Jun 2009
    UNIVERSE
    Just reset 2 counters to zero
    Here to HELP!
  5. The Following 3 Users Say Thank You to immokill For This Useful Post:
    figani (26th October, 2018), mexanico1971 (27th October, 2018), voltechcar (25th October, 2018)
  6. #4
    In EEP
    others dtc in system ?
  7. The Following User Says Thank You to vasa For This Useful Post:
  8. #5
    figani's Avatar
    Feb 2018
    Quote Originally Posted by vasa View Post
    no, only this one... as I wrote in first post...
  9. #6
    May 2018
    @ Gitko. Please, tell us more. Is it possible that's the sensor don't work properly?
  10. #7
    Team dz's Avatar
    Apr 2017
    ALGERIA
    post dump romove dpf and dtc !
    DPF / FAP / EGR / SCR / NOx / TVA FLAP .. etc
    Do not forget to press the button thanks and reputation
    # Algerian #
  11. The Following User Says Thank You to Team dz For This Useful Post:
  12. #8
    Dec 2013
    Quote Originally Posted by Geri12 View Post
    I can't say you it is the problem in sensors or not.
  13. #9
    Dec 2013
    Quote Originally Posted by Team dz View Post
    and what will happen with car when using liquid for reg. , client will need to fill the tank when is necessary. ?
  14. #10
    figani's Avatar
    Feb 2018
    for me the itīs the easiest way to do DPF/EGR/Additiv OFF... but he donīt want it...
    at this moment we have a lot of troubles in Germany... TüV... Diesel Gate...
    before 10 months they check at tehnical control (TÜV) everything, but they dont check CVN, Software and other shit over OBD....
    Now they spend more time with OBD, then to check the brakes...
    And so the most customers are frightend and so on...
  15. #11
    Feb 2012
    Quote Originally Posted by figani View Post
    hi....
    Did you find solution sorting out the Peugeot 508 (code P15B3). Thanks!
