Results 1 to 14 of 14
    Nov 2011
    Romania
    Default passat b6 all key lost
    hy guys can you help me please to pair this dump , they are frim the same car , he have all key lost and i try to make a new oane whit fvdi whit all key lost function and now i have no immo data at all , y can read pin and cs only from ecu...
    Nov 2011
    Romania
    i posted the wrong ecu dump ...this is the write oane
    rob h's Avatar
    May 2011
    Here you go,
    CS : A3 B4 94 6F 47 69 28
    Mac: 1D 4E 20 EC
    Pin: 4651
    Edc16 R4 1.9
  4. The Following User Says Thank You to rob h For This Useful Post:
    Tzepy (25th October, 2018)
    Nov 2011
    Romania
    i have cs and pin but i canot adapt key...
    Nov 2011
    Romania
    thank you ,i have manage to read but when i try to adapt i got secutity fail and when i try to conect to immo whit fvdi al cs pin vin etc are 00000 from ecu i manage to read pin and cs
    rob h's Avatar
    May 2011
    Did you try reading the j393 with a programmer?
    The 95320 eeprom holds all data.
    And did you precode a transponder first, then tried programming using fvdi.
  8. The Following User Says Thank You to rob h For This Useful Post:
  9. #7
    Nov 2011
    Romania
    i precode the transporter but i have read 95320 dump from confort memory only after i have send the comand whit fvdi "all key lost"......
  10. #8
    rob h's Avatar
    May 2011
    You think that you erased youre comfortbox eeprom by obd?
    Or only the key count?
    Simply use the keytool, and add a transponder direct to the comfort eeprom.
  11. #9
    Nov 2011
    Romania
    in confort i don t have cs vin pin nothing. they all 0000 .that s why i post the dumps to ask if is posible to copy immo data from ecu to confort module...i think that bui presing "all key lost" all immo data is erase....
  12. #10
    Nov 2011
    Romania
    or if someoane can help me whit a ecu confort module pair dumps...because when i try to make a new transponder. i can precode cip but when i am trying to learn the cip i got the eroor security acces can not be perform. on ecu i have the pin that you told me on confort module i have pin 0.....
  13. #11
    Jun 2013
    Please give some info like part number on the Comfort module. And which year the vehicle is produced.
    I think it should be possible for someone to modify an existing dump they have in their archive, with your info.
    And after that, I recommend you use a proper tool to add key by dump.
  14. #12
    dijo's Avatar
    Quote Originally Posted by Tzepy View Post
    You have your immo data from Comfort module corrupt, ECU dump is good...
    Post Flash and eeprom from BCM to decrypt your data...
  15. #13
    Nov 2011
    Romania
    can you help me please whit cs pin mac for this bcm dump
  16. #14
    Nov 2012
    HUSI- ROMANIA
    pin 50584
    cs 99 4D FF DD 32 9B FF
  17. The Following User Says Thank You to vorovei constantin For This Useful Post:
    Tzepy (26th October, 2018)
