Results 1 to 11 of 11
    Oct 2017
    Australia
    Default JLR Clone Mongoose Cable Need XP 64 Bit Drivers
    Can anyone help. I need Window XP 64 Bit Drivers for a JLR Clone Mongoose Cable
    Thanks John
    Default jlr 64 bit
    hope this helps
  3. The Following 8 Users Say Thank You to autotrans For This Useful Post:
    bot6six (23rd February, 2023), campitech (4th July, 2024), Joe068 (7th April, 2020), Meat-Head (30th October, 2018), Paddjohn (31st October, 2018), romasi (27th October, 2021), TheNine90 (29th October, 2024)
    Oct 2017
    Australia
    Thank you for your help
    Oct 2017
    Australia
    Could you tell me is this for a cloned cable, thanks John.
    Hi john i have drewtech jlr mongoose , a friend of mine has a clone ( red case ) both seem to work the same.
    The drivers do both with xp or win 7. I believe there are some changes to the jlr program approx mid 2014,
    Need to look into this . regards john
  7. The Following User Says Thank You to autotrans For This Useful Post:
    Paddjohn (1st November, 2018)
  8. #6
    Feb 2020
    Děkuji za pomoc
  9. #7
    Jan 2012
    Hi did you get Mongoose running? i have jlr sdd loaded goes all thro the motions all loads but says VCI not recognised
    any ideas cheers
  10. #8
    Apr 2019
    Hi friends.
    I also need driver for win7 64bit.
    Thanks before.
  11. #9
    Jan 2022
    thank you for your help
  12. #10
    Mar 2023
    nicenicenicenicenicenice
  13. #11
    Jan 2023
    poland
