Results 1 to 4 of 4
Thread: 1998 XJ8 key
    hass42's Avatar
    Aug 2012
    USA
    Default 1998 XJ8 key
    Hello all,
    I have a 98 Jaguar XJ8 AKL
    I tried to program key to key module dump with VVDI and for some reason it keeps sayings unknown version.
    Can someone help in telling if I have good file?
    Or if someone can add key in my dump.
    both key and module dumps attached.
    Hass42
    Quote Originally Posted by hass42 View Post
    Hello all,
    Hass42
    hi
    u file is ok, tmpro can do it ,if u have the module for that
    Memory device - eeprom 93c46 - 8 pin SMD.File size - 128 bytes
    Used in - Jaguar XJ,XJS,XK,XK8
    Transponder to write - Silca T5 - JMA TP05
    Transponder is ready programmed to start the vehicle
    hass42's Avatar
    Aug 2012
    USA
    Quote Originally Posted by key4man View Post
    hi
    I have tmpro but no module for it.
    Last time I quoted a module it was $900 USD for 2006- Rover Sport Cem
    So I just bought vvdi
    Hass42
    hass42's Avatar
    Aug 2012
    USA
    Ok, I found a dump from another key module, same part # LNC, and vvdi did recognize that dump. I program a T5 chip to it and no start. A friend tells me that because it's different dump I have to sync to ecu.
    Anyway to do this with ecu dump?
    Or does anyone know where key info is stored in dump? And what I would need to write?
    Hass42
