Results 1 to 9 of 9
    Oct 2018
    Default Pioneer KEH 9000 RDS code
    Bought this radio in a lot with other old car stereos.
    It was a really high end cassette deck back in those days.
    Of course the code is missing.
    I think there is no code generator for this radio and that some kind of eeprom PDG011 or CXK1011 has to be read.
    Is there anybody here who has some experience with this and can point me in the right direction of where to start?
    I have som pic and eeprom programmers, but don't know if they are correct.
    I have these programmers: K150, CH341A, an old Multiprogrammer V3.5, also have a SOIC8 clip.
    Hi!
    Any 93cXX (93C06) read is, irrelevant because the content can only be "headed" by the code .....
    wbr.
    audio
    https://datasheetspdf.com/pdf-file/9...ion/CXK1011P/1
  3. The Following User Says Thank You to audio For This Useful Post:
    masterskay62 (6th November, 2018)
    Jan 2012
    Wrong info,Try Read Elnec seeprog
    Quote Originally Posted by RadioChiP View Post
    Hi!
    As above, @lanuva wrote about what kind of programming tools are available, so I wrote it to read as Micro Wire 93c06. It will not be a problem with eeprom if you read it. To the point, I correct that 93C46 is a good alternative because we are interested in code # 30h.
    Because he only needs the code, so there is no need to write back that could cause a problem .....
    w.b.r. audio
    Jan 2012
    I have PDG011 Working Good,I try read 93c06/46 standart pinout+rotated Can not read upa+seeprog
    Seeprog only Read select chip PDG011
    All right!
    I do not have PDG or CXK eeprom here, but if you tried it and it was not good I accept it! I just tried to give you an alternative.
    Have a nice day!
    audio
    Oct 2018
    Quote Originally Posted by audio View Post
    Hi!
    wbr.
    audio
    Hi, thanks for answer.
    To make it clear.
    Yes I only need to read, and then probably need some help to decode the file to find the code.
    Do not understand what you mean, 93C06 is a chip,programmer or reader?
    Can any of my K150, CH341A, an old Multiprogrammer V3.5 read this?
    Oct 2018
    Hi, do you mean that only this SEEprog can read this chip?
  10. #9
    Jan 2012
    Yes Seeprog Read & Write Ok
    Upa can Read & Write Select Chip Cxk1011 Ok
