Results 1 to 15 of 16
    Aug 2018
    Default Problems with Smart fortwo ECU
    I hade a working Smart fortwo 2003 with modified ECU...
    The ECU is 0261 205 006
    The car was working with this tuned software but i have planned to sell the car so i wanna go to standard files..
    So i unmounted the ECU and read out the EE prom and the flash memory and saved it for backup.
    Then i mount back ECU and used the Galetto obd/usb interface and flash a standard file for this car/engine
    Now its not working... cluster flashing with one line..
    So i unmount the ECU and unsolder the chips again and replace both file with the one i read out, still not working...
    Is there some memory in the microprocessor i can program to get it to work again or what to do?
    If i take a working ECU from scrap could i reprogram ee memory with the right chassie number?
    figani's Avatar
    Feb 2018
    47 45 52 4D 41 4E 59
    Quote Originally Posted by Myggis View Post
    2003.... 599 or 698 engine...? not that you had flash it with the wrong software...
    maybe you solder points are not good...check it...
    when you connect galletto with ecu, you get ecu id...?
    When I helped you press Thanks and Reputation...
    Aug 2018
    Engine is 698
    I take software from my other car (same engine and year) with galetto in boot mode (ground flash pin 28 in ecu)
    Soldering is correct, double checked
    Galetto cant connect, no id.
    find a similar problem here http://www.digital-kaos.co.uk/forums...-be-written-to
    found cff file in my xentry computer, but dont now how to use
    figani's Avatar
    Feb 2018
    Try to connect and if DAS/Vediamo detect ECU... When not...
    Solder again...
    Aug 2018
    Cant check with Vediamo, dont find it in my computer, only Xentry/Das with C3
    Sep 2018
    australia
    if your joint is dark grey or you moved the chip before the solder set you can have problems.
    have fun everybody.
    Aug 2018
    Soldering is correct and checked, i have soldering almost all my life 😉
    I have a spare ECU so i try to program the chips on this to see if the problem is the same..
    Sep 2018
    australia
    have you tried one of them auto solder sucker irons yet i notice theres a fat one and a new skinny one.
    ive done a bit of soldering but not enough to see dendrites or tin that eats gold tracks.
    i heard if you use winols on this model it calculates a dodjy checksum, worth a check
    have fun everybody.
    Aug 2018
    I dont have any software to tune the files, i have a working ecu and read out the files for backup.
    The car have then been used several months.
    Then i took the standard file for this engine/car and use the Galetto to flash the file, but now the ecu is blocked or something.
    So i unsolder the flash and use my programmer to replace the files to the files i read out but still ecu not working...
    Did you use an oem galleto or fake? mabye thats the problem..
    Aug 2018
    Probably a clone, get it together with a tuningfile to another car bougt on Ebay, so it works when i used it a year ago, everythings look ok when i uploading the flash file..
    Mar 2013
    Europe
    You can solve easy with spare ecu with same Hardware number ;-)
    copy flash and eeprom and all fine ;-)
  13. #13
    Sep 2018
    australia
    i want to blow the back off my smart car, ive got a few ori files if you need it. im keen to get vediamo instructions. maybe somebody can check these.
    have fun everybody.
  14. #14
    Aug 2018
    If i have same ECU from a scrapped working car, can i only modify the EE-prom with correct vin number?
  15. #15
    Sep 2018
    australia
    the eeprom is a soic8 a 24c i think, the format is e2p, the dump can be read with carprog clone via obd2 but im not 100% sure. i would guess and say the 24c soic8 can be transferred over
