Hi people,
I need to read / write Mitsubishi ASX 1.8di 115hp with denso RA6 ecu.
I don't like solder wires on this ecu.
Is there any adapter? If yes, wich one?
Can someone help me out?
Hi people,
Sedat Garip
Chiptuning Remapping, file service, stage 1 & 2 dyno tested.
Diesel + petrol All cars
Manual Adblue dpf egr Opf tested working solutions
Belgium
With Kind Regards,
Don't forget hit thank button if i helped.
there are a view options friend. now thees day you can read all DENSO ecu by OBD if you have the right tools
tool for Denso OBD is not expensive and is very good to have!!
you can also order the Ktag pins with Table. just have to put the pin on the points and you can read and write the ecu without soldering.
hope you have your answer
regards
Hi friend, only this ecu cannot read by obd
I have Kess, AT, geniune, no read.
I have KTAG geniune, but i need solder wires. I need to know wich adapter i need to buy (number adapter) to read this ecu without solder wires.
Sedat Garip
Belgium
With Kind Regards,
because your tools doesnt support the ecu, its not IT CANT BE READ![]()
easy and simple. This ecu reading kess without any problem but we must connect ecu on the table, if Kess not read id must use protocool with Mitsubishi Pajero. Tested several times......
FILE SERVICE
AVDigitale (15th November, 2018), Bobby1970 (12th January, 2020), brmservice (31st March, 2021), gasa (25th January, 2021), giani03 (4th January, 2022), hashimoto-san (7th May, 2022), hbalazs (18th January, 2022), ivchoto1 (12th September, 2021), mikebest (23rd January, 2021), sdtsedat (15th November, 2018), sniegavirs (12th July, 2022), stanislav georgiev (4th January, 2024), YOYOMARTIN2003 (17th July, 2021)
Woww thanksss mate!!!!
Sedat Garip
Belgium
With Kind Regards,
I need read with tricore cable, and choose obd?
Sedat Garip
Belgium
With Kind Regards,
normal obd cable, I use bestdiagcar on the table. The same what this video
https://www.youtube.com/watch?v=HhVqfu_7nu8
FILE SERVICE
How you read it? I see only write in video?
Sedat Garip
Belgium
With Kind Regards,
And one more question, in kess there is no listed this mitsubishi asx car, only in ktag. I choose another mitsubishi? Or choose tricore?
Sedat Garip
Belgium
With Kind Regards,
Send him over mate if it doesnt work, did one last week with X17 OBD
AUTOTUNER, FLEX ,X17, TRASDATA / NEW GENUIS AND ALIENTECH MASTER OWNER.
FULL SWIFTEC AND EVC RESELLER
FILE SERVICE FROM 8AM - 9PM 7/7
BAPRO 4WD DYNO
Did you managed to read it? I have both KESS V2 and Ktag with all the cables , but i also don't want to solder wires (if i don't open the ECU that's even better). Can you please describe me the best option to read it?
I have seen few posts back the pdf with pins connection, but i am not sure which interface was used? it was kess with the cable that have many wires?
Any info would be appreciated.
Thanks!
Hello, i tried to read ecu via x17 original but couldnt connect to ecu.
Also kess clone via protocol sh7058/59 failed.
I can connect actia xs evol with etacs decoder , and play with etacs or delete dtc etc..
At past i had a clone elm327 that one day starded behaving strange, and then ordered a genuine elm327.
But the genuine although connects fine, after some minutes disconnects or has bad pids refresh rate .
Is there something i can check about my. Obd2 port or communication with the ecu.?
Im afraid if there is some damage done to my obd2 port or any fuse or whatever that makes elm 327 to have issues and ecu to cannot be read via obd x17
Any help please
(Asx 2011 1.8 did 4n13 )
You must remove ecu and read/write with breakbox in bench
And use OBD protocol and X17 pinout
BAPRO 4WD DYNO
