Page 1 of 3 123 LastLast
Results 1 to 15 of 39
    Apr 2016
    uk
    Default Need a good opel/vauxhall key programmer
    I need a good Opel Vauxhall key programmer that will work fine on corsa d, astra j and insignia..
    I need it for pin code reading and key programming... I was thinking at smok but not sure if is able to program keys..
    Truecode I was reading here that is a mess with pin codes..
    Any thoughts??
    Inviato dal mio HTC 10 evo utilizzando Tapatalk
    autochei's Avatar
    Mar 2013
    romania
    fvdi 2014.................
    Apr 2016
    uk
    Quote Originally Posted by autochei View Post
    Tried yesterday a insignia... Not able to read pin or program key..
    Oct 2015
    can't read pin insignia but key programming without problem.
    6841707059 576F526B 57416E5453 596F55 526F6B69424152
    jodge's Avatar
    Mar 2017
    pin reading:
    carprog, fvdi, smok, TDB, IOtermial
    Programming:
    Opcom
  6. The Following User Says Thank You to jodge For This Useful Post:
    comizelu (16th November, 2018)
    Apr 2016
    uk
    Quote Originally Posted by rokibar View Post
    Yeah.. I've got the clone.
    During the 10 minutes disconnected twice. After 10 mins fails..
    but if even the original if can't read pin and with such prices and support.... I don't want to hear about it. Thanks
    ghostrider72's Avatar
    Jul 2012
    UK
    AVDI can to that
    Apr 2016
    uk
    Quote Originally Posted by jodge View Post
    pin reading:
    Programming:
    Opcom
    TDB... Is it working well on astra j and insignia? Have you got it or any good/bad reviews? Can't fine many reviews for Opel..
  10. #9
    Feb 2018
    España
    Someone have tested obdstar h111 for opel?
  11. #10
    Sep 2010
    TUNISIA/NABEUL
    zed full good machine for pin code reading and key programming
  12. #11
    Apr 2016
    uk
    Quote Originally Posted by hamidou100 View Post
    I know but they have a bad tokens politic.. Too expensive
  13. #12
    Sep 2016
    (Smok or Iotermintal)+Tango/MK3 solve whole case. Everything will take 3-4min. Read e2 obd2, put e2 into transponder programmer, write key2dump(remote should work), save file and write again to bcm, reset unit.
  14. The Following User Says Thank You to qeso705 For This Useful Post:
  15. #13
    Apr 2016
    uk
    Quote Originally Posted by qeso705 View Post
    There is not Astra j or insignia for tango Opel software...
  16. #14
    drugowaz's Avatar
    Mar 2015
    Lithuania
    Your wrong.look again
  17. #15
    Apr 2016
    uk
    Quote Originally Posted by drugowaz View Post
    This is the description from tradelocks...
