Results 1 to 10 of 10
    jodank's Avatar
    Planet Earth
    Default Op-Com xyz error msg, why? How to solve?
    My OP-COM interface is a clone one with the original PIC inside.
    The firmware is 1.59, if I install it on my laptop I got two problems:
    1. When I start the VAUX-COM as an admin I get a message:
    "An xyz error occured:"
    I don't know what is this for.
    2. If I go to "Test interface" I got a msg:
    "Please connect your interface to the USB port, or install the USB driver!"
    My usb driver is installed and is listed in the Device Manager.
    It shows as "OP-COM USB V2 Interface" .
    The OS is Windows7 32bit Ultima.
    The whole installation I do from the cd what was shipped with the tool.
    I tried to figure out for a week or so what could cos this problem but without success.
    Any suggestion pls?
    Thnx.
    ...version of software?Need change ept file of ftdi in case of use new version.
  3. The Following User Says Thank You to stas12 For This Useful Post:
    jodank (22nd November, 2018)
    jodank's Avatar
    Planet Earth
    On the CD what was with the tool are two versions of the software.
    1. VAUX-COM_120309a+131223d_GB --> this is the version that tells me "xyz" error.
    2. OPCOM 201008 --> this version is working but it is bugging.
    I wanna use the tool on Win7 Ultimate 32bit.
    Thanks for help.
    My best regards.
  6. The Following User Says Thank You to stas12 For This Useful Post:
    jodank's Avatar
    Planet Earth
    Hmmm....Ok.
    Maybe the problem is related to the 1.59 firmware? (I read the description on the link above).
    They are upgrading the firmware to v1.6.
    Maybe v1.59 won't work with the VAUX-COM_120309a?
    Thanks for the reply.
  8. #6
    working,problem is in driver.
  9. #7
    Quote Originally Posted by stas12 View Post
    Where you get it and how you solve it?
    HEX FW 48 available
    Chiptuning solutions - dyno proven
  10. #8
    Quote Originally Posted by jodank View Post
    After spending _many_ hours trying to figure out why this bloody 'xyz' error pops up, I narrowed it down to Windows DEP (data execution protection), that I had enabled globally in the system. After disabling this - all works fine!
    It seems the cracked loader or the soft itself has some protections in it and it does not like Windows messing around with its code.
    i can imagine some AV/antimalware software could make OPCOM/VAUXCOM misbehave too.
    Therefore - it has nothing to do with the hardware or driver.
    Hope it helps someone.
  11. The Following 2 Users Say Thank You to barthek For This Useful Post:
    Brian 01 (3rd April, 2024), JHDSoft (1st October, 2022)
  12. #9
    jodank's Avatar
    Planet Earth
    Thanks for the replay.
    At the moment I can not try your solution but maybe it can be a good solution.
    Hope somebody can also check the solution and report...
  13. #10
    Nov 2021
    Quote Originally Posted by barthek View Post
    Thank you very much !
    I can confirm that it solved the "An xyz error occurred:" for the VAUX-COM (OP-COM) 120309a, my OS is Windows 10 Pro 22H2.
    All i did was: go to Performanece options -> Data Execution Prevention -> select "Turn on DEP for essential Windows programs and services only" -> click "Apply" -> close everything and restart your computer.
    I have read somwhere else that downloading and installing the "Net.Framework 3.5" can also help with this problem. Other fix (which I temporarily did before) may be to install the program in virtual machine (in my case it was Windows 10) with disabled virus protection.
