    Oct 2017
    Default What tools require for immo off ? please help
    Can you guys please let me know what tools and programmers require for reading ecus to get files for immo off...and send to peoples like here.
    What softwares and database are in use.
    How yo guys know if only eeprom is to read or whole ecu.
    For all japanese and americans cars?
    i have almost all key related programers and hardware (from expensive to cheap).
    but sometime problem in ecu and i have to say " No i cant do this car" to customers. Which is embarssing for me..
    Thanks for your time..
    Regards,
    Asif
    Panathaole's Avatar
    Oct 2017
    HELLAS - E.U.
    [QUOTE=Asifmehmmod1;3433421]Hello,
    the most common tool for bench are the ktag, fg tech galletto, mpps,, with that you can read the eeprom and the flash of the most popular cars....
    you can use a simple chip programmer to read- write eeprom, that works good for older ecu...
    carprog also can help you for cloning- copy ecus.....
    you can use programs to make immo off or Virgin ecus.. (in most cases doesn't work well...)
  3. The Following User Says Thank You to Panathaole For This Useful Post:
    Asifmehmmod1 (27th November, 2018)
    dodge69's Avatar
    Mar 2012
    Belarus
    I recommend that you purchase a mini pro programmer in China with all adapters and adapters. This is first of all. With the rest I agree with Panthaole. In addition to all this, you should have the diagnostic equipment of those brands of cars with Cator and you are planning to work! What is not clear or not clear write in private messages.
    thank you if I helpedgratitude motivates me to help further
  5. The Following User Says Thank You to dodge69 For This Useful Post:
  6. #4
    Oct 2017
    Dear,
    i have abrites with all japanese cars licence and other cheap tools like obdstar x300 for key programing...
    in ic readers i have from orange5 to vvdiprog and many other cheap also with all sets.in digonostic tools i have launch and gscan..but digonstic tools only for scan i dont know much about electrician work.
    but for ecu readings i think i have to go for ktag and bitbox..
    but how you guys know this ecu is read flash and this ecu only eeprom..like in tango we have location and clear description what to read ..any immo bypass software.
    szengen's Avatar
    Jan 2017
    i/o terminal............,my accountant knows it well, and I have to work
    fang, Narwalus microcephalus,Spectrum Zx, Atari amiga, Commodore +4
  8. The Following User Says Thank You to szengen For This Useful Post:
  9. #6
    Sep 2020
    thanks to all
