Results 1 to 4 of 4
    GERCOMOTIVE's Avatar
    Jun 2018
    spain
    Default INTRUMENT RENAULT SCENIC 2 FAIL AUTONOMY
    hello friends, I have a problem with an instrument panel of a renault scenic 2,
    It has the typical failure that it shuts down completely.
    After repairing it, everything works fine.
    Less autonomy, they all appear in stripes - - - -
    I have repaired many and I have already found this fault in some and I have never been able to solve it.
    Has anyone else happened? any ideas ?
    Thank you very much in advance
    Usa
    hi
    I don't now your methode
    this a guide maybe help you
  3. The Following 3 Users Say Thank You to quikcar For This Useful Post:
    GERCOMOTIVE (4th December, 2018), JBOU37 (24th March, 2023), Louislesinge (4th December, 2018)
    Louislesinge's Avatar
    Jun 2017
    French Jungle
    It happens many times: try to disconnect engine ECU or battery for a few minutes. If no success reset adaptives to zero in ECU.
    Greetings,
  5. The Following User Says Thank You to Louislesinge For This Useful Post:
  6. #4
    Jun 2018
    spain
    Thank you very much, I will try what you say. Greetings
