Page 50 of 63 FirstFirst ... 40454647484950515253545560 ... LastLast
Results 736 to 750 of 931
  1. #736
    Feb 2022
    france
    Hi, if someone is able to activate renolink for an original obdlink ex it would be awesome.
    I'm looking it for a while. : )
  2. #737
    May 2017
    Can someone activate renolink 1.94 with red obdlink sx?
    Thank u!
  3. #738
    Jul 2018
    Please activate.
  4. #739
    Sep 2016
    hi friends
    the previous year I had an obdlink sx interface and I managed to find his serial with a program
    now I have another interface and I want to know its serial but unfortunately I have
    forgets the name of the program.
    with which software one can obtain the serial obdlink sx.
    can anyone inform me of their name.
    thanks.
  5. #740
    turbocip's Avatar
    Els27baudrate
  6. The Following User Says Thank You to turbocip For This Useful Post:
    gifret (5th March, 2022)
  7. #741
    Sep 2021
    Hello, Renolink V1.98 is done
  8. #742
    Mar 2013
    Hi , i have buy renolink software from renolink europe , but they dont reply ay all . I have send me renolink.txt and no aswer . Can you help me to activate my renolink 198 software
  9. #743
    Sep 2020
    Le havre
    good evening? it may be this: FT_PROG 3.12.11.594
  10. The Following User Says Thank You to Christiano76 For This Useful Post:
    gifret (8th March, 2022)
  11. #744
    Sep 2020
    Le havre
    Quote Originally Posted by gifret View Post
    salut les amis
    l'année précédente j'avais une interface obdlink sx et j'ai réussi ŕ trouver son numéro de série avec un programme
    maintenant j'ai une autre interface et je veux connaître son numéro de série mais malheureusement j'ai
    oublié le nom du programme .
    avec quel logiciel on peut obtenir le serial obdlink sx.
    quelqu'un peut-il me donner son nom.
    merci.
  12. The Following User Says Thank You to Christiano76 For This Useful Post:
  13. #745
    Sep 2021
    Hello, Renolink V1.99 is done
  14. #746
    Apr 2022
    Dear all,
    I would like to program new keycards for my Renault Espace IV JK 2005 Phase 1. I already went through all the 50+ pages of this thread, but the solution is still unclear to me. This is my story:
    I bought four blank keycards with PCF 7947 and a blue cable 1.52 from Aliexpress which included the software.
    ELS27Baudrate.exe tells s/n 113010872966, firmware version STN1130 v4.0.1. Apparently, it is one of the numbers which are blacklisted at least in future software versions as far as I understand the blog here.
    Unfortunately, the cd was so bended that I was not able to read it with my computer. The seller provided me with a download link to rar file which included a subdirectory „OBDLink SX 2018“ with a renolink.exe and a renolink.dat file, besides the two driver installation routines and the installation video. When I had the time to move on, I noticed that the rar file did not include the renolink_setup3.exe file. So I downloaded it from mega_nz based on a link I found in this post, file was OBDlink SX se143.iso, and used the setup program renolink_setup3.exe in there. On my Windows 10 PC, file size is 77.294 kB.
    After the initial installation, the message bar says: "Interface not connected Diagnostic not running". Changes in latency or baudrate adjustment with ifprep2.exe yield the same results.
    Then I replaced the renolink.exe and the renolink.dat files in C:\Program Files (x86)\RenOLink with the ones provided by the seller.
    If I keep the baudrate at 115k, use latency 1 or 16ms, start the application, the message bar on the bottom says:
    „Interface connected Diagnostic not running KWP2000 FastInit MonoPoint @ 10400 bps UCBIC/BFR“
    Then, if I hit the connect button, the message box says:
    Trying to connect…
    Error: Invalid interface
    Diagnostic stopped
    Using some other renolink.exe shows the same message bar:
    And then, when I try to connect, in the message box:
    Trying to connect...
    Error: BUS INIT: FB ERROR
    Disconnected
    Diagnostic stopped
    If I use ifprep2.exe, I can switch the baudrate from 115k to 1M, but then the interface does not even connect.
    Both renolink.exe files show version 1.52.
    I have also tried to analyze the renolink.dat file. Apparently it is a zip or rar file which contains two text files: ws.txt and output.txt. Of course, the access to these files is secured with a password which I do not know.
    Since the two weeks dispute time on Aliexpress is over, the seller does not respond any more to my inquiries, which is very sad.
    By the way, I also have a chinese CAN Clip interface which works flawlessly.
    I also do know French pretty well and have a download copy of „Tuto RenOLink par nowen.pdf“, which seems to be a manual in French in accordance with GabiGafu.
    Could anyone please guide me to a working solution, preferably with a minimum amount of further financial investment? It seems like all I need is a renolink.exe version which works with the blue cable with this serial number, and a compatible renolink.dat file as well. In the meantime, I have so many different versions downloaded that I am really losing control of what was from where. So preferably I do restart with some guidance from you, if possible.
    My car is from 2005, so there is no need for latest databases. And all I would like to do is code some keycards. I have already tried to solder the coil of the broken cards, but to no avail.
    Thank you so much for your help, I greatly appreciate it & best regards & cdt
  15. #747
    Member coyotus77's Avatar
    Oct 2020
    Polska
    [CYTAT=FaWe;4320201]Szanowni Państwo,
    chciałbym zaprogramować nowe keycardy do mojego Renault Espace IV JK 2005 Phase 1. Przejrzałem już wszystkie ponad 50 stron tego wątku, ale rozwiązanie nadal jest dla mnie niejasne. Oto moja historia:
    kupiłem cztery puste keycardy z PCF 7947 i niebieskim kablem 1.52 od Aliexpressa, który zawierał oprogramowanie.
    ELS27Baudrate.exe mówi s/n 113010872966, wersja oprogramowania STN1130 v4.0.1. Najwyraźniej jest to jedna z liczb, które są na czarnej liście przynajmniej w przyszłych wersjach oprogramowania, o ile rozumiem blog tutaj.
    Niestety płyta była tak pogięta, że ​​nie mogłem jej odczytać na moim komputerze. Sprzedawca dostarczył mi link do pobrania pliku rar, który zawierał podkatalog „OBDLink SX 2018” z plikiem renolink.exe i renolink.dat, oprócz dwóch procedur instalacji sterowników i wideo instalacyjnego. Kiedy miałem czas, aby przejść dalej, zauważyłem, że plik rar nie zawiera pliku renolink_setup3.exe. Więc pobrałem go z mega_nz na podstawie linku, który znalazłem w tym poście, plik był OBDlink SX se143.iso i użyłem tam programu instalacyjnego renolink_setup3.exe. Na moim komputerze z systemem Windows 10 rozmiar pliku to 77,294 kB.
    Po początkowej instalacji, pasek komunikatów mówi: „Interfejs nie podłączony Diagnostyka nie działa”. Zmiany opóźnienia lub dostosowania szybkości transmisji za pomocą ifprep2.exe dają takie same wyniki.
    Następnie wymieniłem pliki renolink.exe i renolink.dat w C:\Program Files (x86)\RenOLink na te dostarczone przez sprzedawcę.
    Jeśli utrzymam szybkość transmisji na poziomie 115k, użyj opóźnienia 1 lub 16ms, uruchom aplikację, pasek komunikatu na dole mówi:
    „Interfejs podłączony Diagnostyka nie działa KWP2000 FastInit MonoPoint @ 10400 bps UCBIC/BFR”
    Następnie, jeśli nacisnę przycisk połączenia , okno komunikatu mówi:
    Próba połączenia…
    Błąd: Nieprawidłowy interfejs
    Diagnostyka zatrzymana
    Użycie innego programu renolink.exe wyświetla ten sam pasek komunikatu:
    A potem, gdy próbuję połączyć, w oknie komunikatu:
    Próba połączenia...
    Błąd: BUS INIT: FB ERROR
    Disconnected
    Jeśli używam ifprep2.exe, mogę przełączyć szybkość transmisji z 115k na 1M, ale wtedy interfejs nawet się nie łączy.
    Oba pliki renolink.exe pokazują wersję 1.52.
    Próbowałem również przeanalizować plik renolink.dat. Podobno jest to plik zip lub rar, który zawiera dwa pliki tekstowe: ws.txt i output.txt. Oczywiście dostęp do tych plików zabezpieczony jest hasłem, którego nie znam.
    Ponieważ dwutygodniowy czas sporu na Aliexpress dobiegł końca, sprzedawca nie odpowiada już na moje pytania, co jest bardzo smutne.
    Swoją drogą mam też interfejs z chińskim CAN Clipem, który działa bez zarzutu.
    Znam też całkiem dobrze francuski i mam do pobrania kopię „Tuto RenOLink par nowen.pdf”, która wydaje się być instrukcją w języku francuskim zgodnie z GabiGafu.
    Czy ktoś mógłby mnie poprowadzić do działającego rozwiązania, najlepiej z minimalną kwotą dalszych inwestycji finansowych? Wygląda na to, że potrzebuję tylko wersji renolink.exe, która działa z niebieskim kablem o tym numerze seryjnym, a także kompatybilnym plikiem renolink.dat. W międzyczasie pobrałem tak wiele różnych wersji, że naprawdę tracę kontrolę nad tym, co było i skąd. Więc najlepiej, jeśli to możliwe, zrestartuję się z pewnymi wskazówkami od ciebie.
    Mój samochód jest z 2005 roku, więc nie potrzebuję najnowszych baz danych. I wszystko, co chciałbym zrobić, to zakodować kilka kart dostępu. Próbowałem już wlutować cewkę zepsutych kart, ale bezskutecznie.
    Dziękuję bardzo za pomoc, bardzo to doceniam i pozdrawiam i cdt[/WYCENA]
    Przewiń do tyłu wątek i znajdź mój wpis z Renolink 1.49. Działa z czerwonym Obd Link. Nie wiem czy z niebieskim. Dodałem tym programem karty do Espace IV PH 2 2006 r. Msksymalna ilość kart to 3.
  16. #748
    turbocip's Avatar
    @Fawe / find someone who can adapt for you. You will done without no problems. No lot of money.
    Cheers!
  17. #749
    Sep 2013
    garage
    Quote Originally Posted by Mr BLACK View Post
    can you activate this red interface ...i buy from renolink.fr renolink.eu and activation never come...version1.96...thanx
    ..................activation ..?
  18. #750
    Apr 2022
    @turbocip: This is exactly what I try to do here, find someone who can help me... Let's see if there is anybody out there in this forum who will give me some support. My last keycard started with "card not recognized" every once in a while yesterday, so it seems like there is not much time left...
