Chris198 (1st November, 2022)
Yes, but without success. It was not the matter of "Interface not connected", but the matter of "Invalid interface" error. It turned out that the baud rate was probably changed too often (I used RenOLink interchangeably also with software such as PyRen or DDT4All, which required reducing the baud rate) and one time it did not write properly in the interface memory. But I dealt with it by myself. It was enough to restore the factory settings of the interface with the OBDLinkUSBFactoryReset program from the website of the original cable manufacturer (ScanTool.net, LLC) and reassign the correct baud rate (115.2 kbps) using the STNTerm program, also available on the manufacturer's website of the original interface (the method for the original cable described in the post https://www.digital-kaos.co.uk/forum...=1#post3449153 also works for the clone). After this procedure even after changing baudrate to 115200 to 1000000 in IfPrep2.exe I didnt get the Invalid interface message like before. RenOLink worked at the first time, there is no longer an invalid interface message.
karmann (10th March, 2025)
est-ce votre problème décrit dans la vidéo ?https://transfert.free.fr/OgojO3
Here is the software from the video: https://transfert.free.fr/uexQbk
I see that the serial number of your probe 113010980410 corresponds to Renolink 1.99 Chinese. I myself have Renolink 1.87 and 1.99 Chinese and the serial numbers of the probes are not the same.
Try installing Renolink 1.99 with your probe.
Hello friends. I have renolink 1.87, clone installed on Windows 10, activated from Aliexpress. When connecting to the car it throws the message BusInit error: fb error. Can someone give me a solution?
Plug strong your device in obd2 port.
thanks, the obd is inserted full, I can read with another wifi interface and ddt4all. What will be the problem, it must be something simple. Greetings.
hi
how find my renolink tool serial??
thx
Search els27baudrate.exe
My work is my life ART TECH GARAGE
renault1 (11th December, 2024)
I have clone interfaces v1.87, if i try v 1.99, the interface is damage or not working?
Sorry for my english!
Hello everyone. I want to buy original Obdlink sx and Renolink for my Dacia Logan 2019 car for various activations and for programming a new key. I want your advice, to buy original Obdlink sx and original Renolink from Gabi Gafu or Renolink according to Aliexpress, or is there a possibility to reduce costs? what do you recommend me to buy but be ok? Thank you all.
Guys is any website or from where you buy the original?
