Results 1 to 12 of 12
    DK Veteran mariazo84's Avatar
    Default Help for smart search dtc in file
    hello inned search dtc in file I can not locate the code library or translate it.someone can help me
    Help please
    Enviado desde mi iPhone utilizando Tapatalk
    KESSV2-KTAG-ECM TITANIUM-WINOLS-ENIGMA GENUINO CARPROTOOL FULL X-TOOL FULL CPT CARPROG AUTEL KEYS VVDI2-PROG FILE SERVICDE
    May 2017
    Car? Engine? Ecu?
    Chiptuning Files FileService, Damos Files
    EGR/DPF/NOX/DTC/TVA/VSA/ADBLUE/Lambda OFF...
    Licensed: WinOLS, RACE 2000, ECM Titanum, ESS
    Master: Kess,Ktag, HPTuners,
    no personal info in sigs !!!
    Is Ecu smart by mercedes benz
    The Bosch Ecu number is 0261205006 - 1037369463
    Help thanks
    Help
    Aug 2012
    Quote Originally Posted by mariazo84 View Post
    Help
    write not 20 times help help help !!!
    post what dtc off u need what p code what error text !
    and all infos about car
    engine
    ecu
    and so on
    Tuning Cars and Trucks, Immo off , DTC delete, DPF off
  9. The Following User Says Thank You to icezero2010 For This Useful Post:
    mariazo84 (19th December, 2018)
  10. #9
    The Car is smart fortwo engine g15 45kw 2004
    Dtc Off Need p201b p201f p201d p2019 p2027 p2012
  11. #10
    Aug 2012
    rep the car dtc delete on this dtc not work
    also limp mode and no power the one u have after delete is a clear error space
  12. #11
    I do not understand
  13. #12
    Aug 2012
    I do not understand
    simple dtc delete work only if u have no limp mode
    if u only kill the dtc u get no error ok but the situation is the same with error LIMP MODE
    u must repair the car
  14. The Following User Says Thank You to icezero2010 For This Useful Post:
    bobolin4o (2nd January, 2019)
