Results 1 to 5 of 5
    Aivis3's Avatar
    Sep 2016
    Latvia
    Default Volvo V50, 1.6d, very need correct (Not DPF switch only) DPF/EGR OFF please...
    Very need correct (Not DPF switch only) DPF/EGR OFF please...
    Volvo V50, 2007
    BOSCH, EDC16C34
    0281011775
    8692329
    4N51-12A650-BA
    sw: 372468
    Thanks!
    If helped - "Thanks" and "Reputation" please
    Aivis3's Avatar
    Sep 2016
    Latvia
    In several DPF OFF examples I can see that it is touched address:
    How to correct disable DPF?
    1C4C36 (12x1) - ?
    1C4C68 (12x1) - ?
    1DF15E (18x15) - ?
    1DF57C (17x17) - ?
    1E8D8C (1x1) - DPF Switch
    1E8D8E (1x1) - ?
    How to correct disable EGR?
    Are these three maps to zeros?
    1C4516 (8x1) - EGR
    1C4538 (8x1) - EGR
    1C455A (8x1) - EGR
    Aivis3's Avatar
    Sep 2016
    Latvia
    Can someone check the my DPF/EGR/DTC OFF ?
    I need to know, correct or no... DTCs removed: (Maybe some I have forgotten?)
    DPF:
    ECM-2A00 Pressure sensor particle trap.
    ECM-2A10 Temperature sensor, particle trap
    ECM-2A20 Particle trap. Defective signal, D4164T
    ECM-2A30 Particulate trap. Overcharged, D4164T
    ECM-2A40 Particulate trap. Blocked, D4164T
    ECM-2A50 Particle trap. Defective signal, D4164T
    ECM-2A60 Particulate trap. Faulty function, D4164T
    EGR:
    ECM-441D Exhaust gas recirculation (EGR) control. Faulty signal, D4164T
    ECM-4420 Position sensor (EGR).
    ECM-4438 Exhaust gas recirculation (EGR) control. Jammed, D4164T
    ECM-444D Exhaust gas recirculation (EGR) control. Offset error, D4164T
    ECM-445D Exhaust gas recirculation (EGR) control. Offset error, D4164T
    ECM-4460 Exhaust gas recirculation (EGR) control. Jammed, D4164T
    ECM-4477 Exhaust gas recirculation (EGR) control. Flow too low, D4164T
    ECM-4487 Exhaust gas recirculation (EGR) control. Flow too high, D4164T
    ECM-4490 EGR valve. No signal, D4164T
    ECM-44A0 EGR valve.
    ECM-44B0 EGR valve.
    ECM-6710 EGR regulation. Flow too low, D4164T
    ECM-6720 EGR regulation. Flow too high, D4164T
    Checksum:
    ECM-7700 Engine control module (ECM). Faulty check sum, D4164T
    ADM:
    ECM-A600 Additive dosage module (ADM). Faulty signal, D4164T
    ECM-A610 Additive dosage module (ADM). Faulty signal, D4164T
    ECM-A620 Additive dosage module (ADM). Faulty signal, D4164T
  4. The Following 3 Users Say Thank You to Aivis3 For This Useful Post:
    t-ortman (31st August, 2022), user202 (20th June, 2023)
    Sick world
    Hi do you have eeprom please?
    Aug 2018
    Quote Originally Posted by Aivis3 View Post
    DPF:
    EGR:
    ECM-44A0 EGR valve.
    ECM-44B0 EGR valve.
    Checksum:
    ADM:
    Hi, what software do you switch off these DTCs?
    Regarding the modifications in my opinion:
    - EGR Hysterisis zero OK
    - Post injection maps zero OK
    - DPF Switch zero OK
    Some other stuffs I didn't know
