Results 1 to 12 of 12
    Lithuania
    Default b1613 front sub sensor rh initialization error
    Hi, I removed crash with Carprog, but still have one error
    b1613 front sub sensor right initialization error
    I can delete error , but after restart car it cames back. I tried to replace with left sensor, but still have same error.
    Where could be broblem.
    ateyourv8's Avatar
    Feb 2018
    Down Yonder
    What car is this? year make and model?
    Lithuania
    Sorry, its Subaru forester 2014 USA
    srs ecu 98221SG001 with renesas
    ateyourv8's Avatar
    Feb 2018
    Down Yonder
    Has this module been cleared after crash or did the error come up on its own?
    Check continuity from the sensor plug to the module. Maybe a break somewhere in the harness. If that all checks out, id say module.
    I had issues with one of these also. Error for driver seat airbag after clear even though drivers seat bag was never deployed. Ended up being the module.
    Lithuania
    Hi, error was before clearing,. I can clear error , but it came back after restart.
    I have same error even with disconnected sensor.
    But If I disconnect left side sensor I got different error ( sounds that sensor disconnected )
    Jul 2016
    anywere
    CHECK THE WIRE SOME TIMES CUT INSIDE
    PUT THE SENSOR RH INTHE LF SIDE AND ERASE CODE IF CHANGE CODE FAULT IS THE WIRE SIDE
    Lithuania
    Very strange situation.....
    If I disconnect left sensor, I have only error about left sensor initialization, but errors about right sensor disapares, even with disconnected right sensor . ONLY left sensor error !!
    When I connect Left sensor, I got error about right sensor , And left sensor error can erase and didnt come back.
    So if I disconnect both sensors I got only one error about Left sensor, if both connected I have error abouy right sensor. Tried to swap sensors but the same.
    I cut wires and connected sensord near srs module. Does possible thar error in ODS ???
    FxShaw's Avatar
    Nov 2013
    Outta This World
    Sounds like one of the impact sensor might be incorrect..check the part # and post them.
    A cut wire can also trigger the same code too.
    🔥Wacka Wacka 🔥
    Lithuania
    Both the same part nr.
    I connected both with new wires near srs computer
    Jul 2016
    anywere
    and the two code fault number?? please
    Lithuania
    if I disconnect both sensors I have only error on left side
    b1618 front sub sensor Left initialization error (current)
    b1618 front sub sensor Left initialization error (The past)
    If I connect left sensor and connect or disconnect Right sensor I get sane error
    b1613 front sub sensor right initialization error (current)
    b1613 front sub sensor right initialization error (The past)
    ateyourv8's Avatar
    Feb 2018
    Down Yonder
    Have you checked for a short in the wires? Take each wire and check for short against the other 3 wires from both sensors. Sounds like something is shorted between the two sensors. The part numbers are correct and yes both sides are the same.
