Results 1 to 15 of 15
    Dec 2018
    Norway
    Default KKL cable that works with VAG EEPROM Programmer V1.19g ?
    Hi.
    can anybody post link to an KKL cable that works with VAG Programmer V1.19g
    saw somebody post (get a real KKL cable) most cable i find on internett cost 5-10$, and will not work?
    or software and cable, so i can get IMMO pin from 2004 audi allroad EDC15VM+
    Feb 2017
    VAG Programmer V1.19g doesn´t work for me with a EDC15VM+ from a 2.5 TDi AKN Passat 3BG too.
    I use for this EDC VAG-K+CAN COMMANDER FULL 2.5 for EEPROM read.
    As KKL cable i use my original VCDS HEX+CAN cable in dumb virtual comport mode.
    But every cheap and simple KKL cable with an usb to serial chip inside should work.
  3. The Following User Says Thank You to Kabel For This Useful Post:
    chriss1980 (2nd January, 2019)
    Dec 2018
    Norway
    Hi Kabel.
    thanks for reply.
    Did you use Win XP32 or other?
    When using EDC VAG-K+CAN COMMANDER FULL 2.5, did you do anything special with drivers to make it work with VCDS HEX+CAN cable?
    I have VCDS HEX+CAN cable
    Dec 2014
    PL
    Hi.
    The Vcd$ cable works only with dedicated VCD$ software. Software vag k can commander 1.4 / 2.5 / (4.5 / 5.1 BETA only CAN) will work with dedicated device and vag kkl device. Both interfaces additionally work with vag eepromprogrammer 1.19g.
    I have vag kkl and vag commander 1.4 / 2.5 from China. Both work with these software on WIN XP, WIN 7 and WIN 8.1. Vag kkl is on CH340 drivers and vag commander on FTDI.
  6. The Following 2 Users Say Thank You to Mario6 For This Useful Post:
    chriss1980 (2nd January, 2019), EndSky (10th April, 2019)
    Feb 2017
    @chriss1980
    I use Win 7 32 Bit
    I´ve just selected the right com port in VAG CAN COMMANDER.
    @Mario6
    Thats not true with VCDS.
    You can switch it with officially drivers to work as a normal usb to KKL interface with com port. With these special drivers you could use it on the same computer with VCDS and as an KKL cable (of course not at the same time).
    https://sites.google.com/site/imnuts...ch-vcp-drivers
    and please read carfully. I´ve got a HEX+CAN
    http://www.ross-tech.com/vag-com/usb...l-com-port.php
  8. The Following User Says Thank You to Kabel For This Useful Post:
    chriss1980 (3rd January, 2019)
  9. #6
    Dec 2014
    PL
    Kabel
    Maybe you're right. I used these drivers with my old 12.12.0 EN. I had VCP but unfortunately it did not work like vag kkl with VCDS Lite 1.2 (port com OK interface not found), Vag commander 2.5 (port com failted or not connected) or vag eeprom 1.19g (ECU not found). Maybe I was doing something wrong. I have all these interfaces so I do not bother that too much. They are all cheap.
  10. #7
    Dec 2018
    Norway
    @Kabel
    I have tried, but failed, multiple times. installed VCP drivers, and select COM2.
    disabled "boot intelligent mode" in VCDS.
    get message "RX timeout" and "ECU not found" when I select connect to Dash or ECU
    Must be something i do wrong. open for suggestions.
    PS. Tried with WinXP-32, and Win8-64.
    Last edited by chriss1980; 3rd January, 2019 at 07:32 PM. Reason: additional info.
  11. #8
    xoom's Avatar
    Ylakiai
    D-CAN cable for Inpa works fine with VAG EEPROM Programmer
  12. The Following 2 Users Say Thank You to xoom For This Useful Post:
    chriss1980 (3rd January, 2019), hmagga (14th June, 2024)
  13. #9
    Dec 2018
    Norway
    Dec 2014
    PL
    chriss1980
    So you have the same problem as me. Just buy one of these cheap ones. They will work too. I advise on FTDI controllers.
    https://pl.aliexpress.com/wholesale?...chText=vag+kkl
    https://pl.aliexpress.com/wholesale?...+can+commander
    https://pl.aliexpress.com/wholesale?...Text=bmw+inpa+
  15. The Following User Says Thank You to Mario6 For This Useful Post:
    chriss1980 (4th January, 2019)
  16. #11
    Feb 2019
    Hello Everyone
    I have HEX-Net from Ross-tech can I use it with VAG EEPROM PROGRAMMER 1.19g ???
    if yes how , if no what can I use for EEPROM reading/writing ?
  17. #12
    Jun 2019
    It is possible to use VAG TACHO USB 5.0 cable? (FTDI FT245RL chip)
    Seems to recognize the interface, but show an error like "ECU not Found" whatever I can try to read.
  18. #13
    Jul 2019
    Quote Originally Posted by chriss1980 View Post
    Hi.
    This function is very buggy and 99% of the time do not work.
  19. #14
    Jul 2019
    Quote Originally Posted by valipolo9n2004 View Post
    I do not think it will work .
  20. #15
    Jan 2019
    I Have a kkl cable blue with ch340, IT will work with eeprom vag programmer or vag commander 1.4 ?
