Jose Santana (22nd April, 2019), Ramtamtam (18th June, 2021)
This is the complete file https://wetransfer.com/downloads/810...4193817/5e6997
Files are now on the sd card. do i need to encrypt the file again? if i put it in the kess, turn it on it says EEFFACE error
You must first decode your original SD so that you can read it.
that should look like this:
00000000h: EB 3C 90 4D 53 44 4F 53 35 2E 30 00 02 40 08 00; Ã~ <MSDOS5.0 .. @ ..
00000010h: 02 00 02 00 00 F0 F4 00 3F 00 FF 00 00 00 00 00; .....?. à ° A '. ÿ .....
00000020h: 00 A0 3A 00 00 00 29 A5 C6 CF 51 4E 4F 20 4C 41; , : ...) ¥ Ã † Ã QNO LA
00000030h: 42 45 4C 20 20 20 46 41 54 31 36 20 20 20 00 00; BEL FAT16.
Integrate the image as a virtual drive or copy it to a SD-card,
then copy the folders and files to your new FAT 16 formatted SD and then encrypt them again with the new KEY.
every SD-Card has it own KEY
If you've done it before its maybe easy?
I never worked with hex.. never worked with a sd card...
Your tutorial is missing alot of info.
the img file i created looks like this
00000000 EB 3C 90 4D 53 44 4F 53 35 2E 30 00 02 40 02 00 ë< MSDOS5.0 @
00000010 02 00 02 00 00 F8 EF 00 3F 00 FF 00 00 00 00 00 øï ? ÿ
00000020 00 B0 3B 00 80 00 29 31 FA BE B8 4E 4F 20 4E 41 °; € )1ú¾¸NO NA
00000030 4D 45 20 5F 31 32 46 41 54 31 36 20 20 20 33 C9 ME _12FAT16 3É
I formatted the sd card into fat, copy the files into sd card, should be 4 maps? (file, log, system and update?)
Crypted it with the tool and wrote the .img back on the sd card. still can read the sd card shows just alot of folders.
When i insert the sd card into the kess it says EEFFACE error.
you say i have to encrypt them again with NEW KEY? what is the key of it? is it the CID? the 13 lines we copyed?
Edit:
In your tut you say uncrypt and decrypt its the same thing right?
So first make it readable, edit with hex first lines into :
Then read the file, have alot of weird folders in it...
Copy them?
format sd card and put the files back in the sd card
Use xorfiles to crypt the file again and write the .img file into the sd card again?
@mrwolfie
Sorry that a lot of information is missing in my manual and that I have published my manual.
If I had known that I only confused people, I would not have written them.
in my manual is written:
"then the start same Procedur to create a new “SD128 MB XOR Key01-13.img” file with new SDCard
Key."
karol123 (17th January, 2019)
This guide is present online, even the file is identical :-)
Chip tuning professional.Winols original 4.30.File processing, DTC, DPF and EGR off.PCB Kess 5028, Ktag 8000.
Optimized SD Card files for any SD card CID
delete delete
mate, you make great tutorial
bergbahn (17th January, 2019)
bergbahn (18th January, 2019)
I never said its not working.
I asked if he can add some more info that a noob like me can do it
I have a request to all, can you complete my guide to make it easier to understand?
just post all tips here
mrwolfie (18th January, 2019)
on youtube i found this
Any got the file, keyfilegenerator.cmd?
