Results 1 to 15 of 22
    dewsbury west yorkshire
    Default bmw cas dde sync
    ive purchased second hand ecu and tried to program isn into cas using avdi, not able to do. the ecu isn avdi picks up is 4 digit AA 20 cas isn 00 00 7D 97 the 16digit pick up all FF
    avdi has tried to modify cas but ecu report ews interface error, not sure if cas eep is messed up can any1 help to sync the unit together thx
    doctore's Avatar
    Nov 2015
    Colorado Denver
    Here you goo
    sinhro ecu cas on obd and fire car
    Professional bmw key service cas 3/3+ 4/4+ repair = reset ews egs 8hp = 6hp-egs19d
    i tried this it didnt work any other solution thx
    doctore's Avatar
    Nov 2015
    Colorado Denver
    you write this dump and car wont fire
    post pictures from cas unit
    yes i tried to syn with avdi still ews tampering
    doctore's Avatar
    Nov 2015
    Colorado Denver
    ews tempering becose your file its not synhro i give you fail with both same isn did you write him back or not
    i used bmw isn program got the same file as your but car didnt start ive compared both file they are same
    Mar 2018
    Are you using avdi online? I did the job succesful. 00 00 AA 20 is your dme isn, write it with avdi online. sync your cas dme and it wil be fine. If use avdi off line you dont see 00 00 if read or write but it is ok. than you put in AA 20 and sync cas dme.
    Mar 2018
    Some times you need to put key out of car for a 1 min.
    doctore's Avatar
    Nov 2015
    Colorado Denver
    Quote Originally Posted by dashtec View Post
    faind on dk another eprom for your cas
    yes i tried with avdi online say cas write ok sync with avdi still has ews interface error if i get another eeprom for cas3 will i need to code key key
    Mar 2018
    yes you wil need new key, or someone can repare your file. Does the car crank but dont start?
  13. #13
    yes thats right i think avdi might have messed eeprom up
  14. #14
    Mar 2018
    does it say bad sync like picture?
  15. #15
    yes says bad sync
    when i read cas says 00 00 7D 97
    ecu AA 20
    SO I EDIT CAS TO 00 00 7D 79 THEN WRITE
