Results 1 to 9 of 9
    May 2016
    Default Ducato 2011 TRW 1367537080
    Hi, can somebody clear the crash from that airbag module there is 25lc320. Tried with NEO8 but there is still B101C fault code.
    Thanks in advance.
    slick_dick's Avatar
    Essex
    here try this
    “There's nothing more dangerous than someone who wants to make the world a better place.” ― Banksy
  3. The Following 2 Users Say Thank You to slick_dick For This Useful Post:
    JareckiPL (23rd November, 2022), lbnsky (17th January, 2019)
    May 2016
    Still that same dtc
    slick_dick's Avatar
    Essex
    whats the description of that dtc?
    May 2016
    Driver seatbelt circuit malfunction. When I unplug it there is an extra error b100b - driver seatbelt tensioner malfunction. Tried to put resistors in but nothing changed. Maybe it is a hardware issue?
    slick_dick's Avatar
    Essex
    measure continuity theres probabley a break in the wire
    May 2016
    Wires are ok and seatbelt buckle was replaced. There must be airbag sensor faulty.
    slick_dick's Avatar
    Essex
    what about the plug on it, is it partly broken.
    if no internal error u still might have a chance
    regards
    slick
  10. #9
    May 2016
    I think that the chip on the pcb mlx16305 might be faulty I checked datasheet and see it is responsible for recognize fastening the seatbelt. I found on ebay that somebody is repairing ecus with exact symptom on fiat airbag sensors.
  11. The Following User Says Thank You to lbnsky For This Useful Post:
    klonone (1st April, 2023)
