Results 1 to 11 of 11
Thread: Vag edc17cp14
    eepromdom's Avatar
    May 2017
    Based in villieria, Pretoria. South africa
    Default Vag edc17cp14
    Guys I need help pls... I'm trying to clone an 022 Audi edc17. I read the orig file via k tag on the bench. And I also made a backup of the new ecu I wanna transfer the software to ... So i wrote the orig file onto the new ecu. It successfully wrote but I still have immo problem? Pls help. What am I doing wrong? O tried serial programming activation on both ecus... Saved the patch files wrote the patch orig files into the new ecu? Nada... Diagnostics reveals only ecu start blocked by immo? What's the correct way forward... My deepest thanks in advance... What files should I write into the new one... Its the iron/from tricore tc1796 without external flash. Eeprom is in tc1796...
    no passwords here..i aint trolling for a gold star.. love this forum
    Top Poster rojhat's Avatar
    Sep 2015
    france
    Quote Originally Posted by eepromdom View Post
    hi immo its not clonable . if you want start make immo off with same ecu number .
    Envoyé de mon SM-A605FN en utilisant Tapatalk
    eepromdom's Avatar
    May 2017
    Quote Originally Posted by rojhat View Post
    Thank you for the advice brother... I saw they say its otp and some areas of file are not rewritable... The original box is 03l 906 022jr and the new box is 03l 906 022bd. Ktag shows same software no for both... Can I rewrite the new ecu back to the original file that was on it and immo off that one? The launch reveals no other codes besides immo? And are you able to help if I post the original file on the new box I wanna put in this car? Although I pulled the original ecus file the box is a gonner...
    Once again..I know time is money so thank you for helping me figure this one out...
    Sep 2015
    france
    hi if you want good off post original ecu full read and replace ecu full read separatly data no ktag backup and im make it on off after you try as you want.
    for starting car im sure for compatibilty not sure all ok
    eepromdom's Avatar
    May 2017
    Thank you. I will send tc1796 flash and tc1796 eeprom files separately from each respective ecu tomorrow for you to try.. Thank you. Ill post them tomorrow for you..
    avital's Avatar
    Upolad both dumps , it is ECU with WFS5 immo.
    Production and development professional IMMOBILIZER/TCU/ESL/ELV/SRS emulators for all brand cars
    PORSCHE / FERRARI / MASERATI / LAMBORGHINI - immobilizer solutions
    post eprom+mpc data from old and new ecu.
    i can transfer the old immo data.it need to be preparied. only whrite cant works.
    eepromdom's Avatar
    May 2017
    Quote Originally Posted by ladadens1 View Post
    Here are the files. Thank you ...
    eepromdom's Avatar
    May 2017
    Couldn't attach files... Here ill try again...once again... Thank you..edc17 new box eep.zipedc17 newboxmpc.zipedc17 origeep.zipedc17 origmpc.zip
    avital's Avatar
    Your eeprom for donor with stored org immo data:
    pass in PM.
  11. The Following User Says Thank You to avital For This Useful Post:
    eepromdom (21st January, 2019)
  12. #11
    Dec 2018
    [QUOTE = avital; 3478951] Seu eeprom para doador com dados armazenados de immo da organização:
    passe em pm.
    EDC17CP14_WFS5.JPG[/ CITAR]
    Amigo, qual software você usa para descriptografar o ecu edc17?
