Results 1 to 15 of 30
    Dec 2018
    Default USB Driver incorrect after installing 2016 Delphi
    My hardware is a gold DS150e, 30250, it was working fine with 2014.4 & install & activation of 2016 went well. I installed on a new PC ( win7 pro 32) manually selecting USB driver from drivers folder in 2016 folder & get error no driver found,
    In device manager, "AUTOCOM CDP USB "is showing & driver install problem shows.
    Dec 2014
    PL
    So maybe use the drivers from 2014R2 or 3. I think they are the same as 2016R0. I did not have any problem on WIN XP, WIN 7 64, and now on WIN 8.1 64, Maybe you need to disable the driver's digital signature request. (I had it on WIN 7 64 with OPCOM Opel)
    Feb 2018
    Try this, install this driver when you unpack and uninstall what you have.THANK+REP.
  4. The Following 39 Users Say Thank You to zoki21 For This Useful Post:
    ANDBODAS (13th November, 2019), beldeczki (23rd February, 2020), blacksucces (11th January, 2020), bubus66 (19th April, 2020), daniersms (21st August, 2020), darkwooddark (11th April, 2020), Deonic (23rd September, 2020), dinar (4th February, 2019), dsfds (1st March, 2020), ECU2009 (17th April, 2020), ecufix (13th April, 2020), fane_81 (14th November, 2019), freesurfer1975 (1st March, 2020), geobxl (3rd September, 2019), gixiwom820 (7th March, 2020), Helix (21st March, 2020), izgisrac (28th August, 2020), LSDJ (2nd January, 2024), Matttes (24th January, 2019), misa2 (13th June, 2021), mps125 (30th October, 2020), mudbusters (13th November, 2019), nesko0707 (6th April, 2020), Pilaj (18th November, 2022), Qlion (4th February, 2020), sanemalkavian (17th August, 2020), sourceteam70 (27th April, 2020), Spetan (3rd April, 2020), ti247 (26th July, 2021), UKTCHunter (17th May, 2020), UrosM96 (2nd November, 2020), xprog020 (30th October, 2020), XtremePr0 (30th July, 2023)
    Feb 2020
    Thank You for drivers
    Feb 2020
    thanks for the driver it work !!
    Feb 2020
    Will it work on win 10? having troubles...
    Newbie Helix's Avatar
    May 2018
    Italy
    Thanks for the drivers, mate!
    Feb 2018
    push thanks
  10. #9
    Apr 2020
    Thank you!
  11. #10
    Jan 2018
    Thank you!
  12. #11
    Feb 2018
    push thanks
  13. #12
    Stelaras26's Avatar
    Nov 2017
    Skyrim
    Just for knowledge,if you installed 2016 version which is packed in an .exe file,driver folder has the issue.Maybe
    You already knew that.But its the version thats faulty
    If i Helped you,use thanks and rep button to thank me back
  14. The Following User Says Thank You to Stelaras26 For This Useful Post:
    Meat-Head (23rd May, 2020)
  15. #13
    Feb 2018
    only drivers are expected on 2016, and these I have set up solve the problem
  16. #14
    Apr 2020
    i had the red delphi with 2014 software. after updaten 2016 software it wont find the vci. I see also 2 problems with the drivers. I cant update them. Can i use the same file
  17. #15
    Jul 2020
    Hi i will try it and tell you if working, i searched everywere man and no solutions!
