Results 1 to 5 of 5
    world
    Default Vag Eeprom Programmer with Vcds cable ?
    Hello there,
    I need to use the Vag Eeprom programmer tool, but i dont have the interface for it. Is it possible to use this tool with VCDS, or ELM327... similar stuff?
    Oct 2017
    Germany
    you need simple k-line adapter for this software. Maybe it wil work with VCDS in "dumb mode", if available...
    Dec 2014
    PL
    Vag eeprom 1.19g works with:
    -vag kkl
    -vag k can commander
    -BMW Inpa K D Can (I did not check)
    Someone wrote that vcd$ would work after changing the drivers with the virtual com port. I tried but it did not work. Here you have a link to the drivers.
    http://www.ross-tech.com/vag-com/usb...l-com-port.php
  4. The Following 2 Users Say Thank You to Mario6 For This Useful Post:
    EndSky (10th April, 2019), gsmflasch (21st January, 2019)
    world
    I have original VCDS and original VCP but with both its not working :-(
    I try the drivers also but still no connection with vehicle..
    Dec 2014
    PL
    I have the same on the vcd$ cable. But I have both vag kkl and vag k can commander. Just buy the cable vag kkl or vag k can commaner 1.4 / 2.5 (on FTDI controllers). It costs 11-15 dollars.
  7. The Following User Says Thank You to Mario6 For This Useful Post:
