Any one got instruction or video with lonsdor k518ise tool how to program Toyota Corolla-Verso 2008 all keys lost.
super jumbe (25th January, 2019)
The issue I am having is at the start I can not backup the dump it says switch on dash and download dump every time it says failed any idea.
This one has 2 button smart key push start/stop button.
if it's first time and you want to be sure, take out the smart box and save the eep. Mosty 93Cxx
super jumbe (26th January, 2019)
2008 isnt true smartkey. Best for them was Orange 10$ Toyota tool. Try to do it via regular 4d key.
This is the remote I have orange toyo tool do I use 4D 67 chip?
Put key in slot and put Orange tool in obd without pressing anything. In 30s you should have immo resseted and first key learned. For remote find manual procedure it is somewhere here on dk.
Remote manual process
Open driver's door The driver's door must be open and unlocked
Key out of the slot
1. Insert and remove the key from the slot switch 2 times within 5 seconds
2. Close and open driver's door TWICE
3. Insert the key into the slot and remove it
4. Close and open the driver's door twice
5. Insert the key into the slot
6. Close the door
7. Turn the engine switch ON and OFF within 1 second - do this once to ADD a remote and twice to rewrite remotes
8. Remove the key from the slot
9. To confirm programming mode, the power locks will now cycle "lock" to "unlock" once
Within 40 seconds of Door Lock confirmation:
A. Press both transmitter Lock and Unlock buttons simultaneously between 1 and 1.5 seconds and release.
B. Within 3 seconds of step A press the transmitter Lock button for more than 1 second and release
Open driver's door
What is the procedure for coding 2 keys using Orange Tool? When do you put the 2 key in the ignition?
