Results 1 to 13 of 13
    Nov 2013
    Default Skoda Fabia error B2000
    good morning guys, I have a problem with a skoda fabia in the module airbag error b2000 which in its day and solve with another car the same, but today it is impossible to remember or find the file you use.Can you please help me eliminate this error? coding with vcds there are no options for this ecu, I use 12.12 thanks so much for even reading me. I would appreciate any help.
    BOSCH 6R0959655 K
    Mar 2017
    Colombia
    http://wiki.ross-tech.com/wiki/index.php/B2000
    and to inspect the system?
    check with another dump, so have crash..ç
    https://www.google.com/search?q=6R09...w=1366&bih=626
    WINNER THE LOSER
    Nov 2013
    thank you for answering, I already read the rosss tech website, I have put 9 files of the forum and some kept showing up and in others I did not leave but had other options that mine does not bring and I can not recode.
    Nov 2013
    I tell you that I have already been able to solve it, I have searched for a new file and I have recoded airbag and it works perfectly.
    DK Veteran kevino's Avatar
    Slovakia
    please clear code b200 ecu defect. stored 3 times in ecu. no crash data. I use nyo to clear crash but no solution for this code b200
    thank you
    VCDS 17.1.3, Xprog M 5.0
    robert1232's Avatar
    Dec 2010
    Ireland ;)
    Default here is your file
    thanks+reputation=pass
    raport
    Quote Originally Posted by kevino View Post
    thank you
    PRESS THANKS AND REPUTATIONS (STAR) BUTTON
    I don't give others the password to the file. I'll send my file and I'll try to make it
  7. The Following 2 Users Say Thank You to robert1232 For This Useful Post:
    kevino (11th December, 2019), Marin356 (25th March, 2022)
    Slovakia
    Not working. I try clear with vcds 17 but same faults. See txt. Thanks
    dragon100's Avatar
    Jan 2012
    From land of milk and honey
    Kevino, check my repaired file ...
    Scripts for Multi-PROG
    Best regards.
    Dragon
  10. The Following User Says Thank You to dragon100 For This Useful Post:
    kevino (12th December, 2019)
  11. #9
    Slovakia
    not working friend. same faults. it is waste of my time and yours. ecu goes to trash. thank for your time and help.
  12. #10
    You must test in the car, not outside the car.
  13. The Following User Says Thank You to Hack01 For This Useful Post:
    kevino (13th December, 2019)
  14. #11
    Slovakia
    In car it works. Thank you very much.
  15. The Following User Says Thank You to kevino For This Useful Post:
    reproteq (19th December, 2019)
  16. #12
    dragon100's Avatar
    Jan 2012
    Which file work ok ?
    Best regards.
    Dragon
  17. #13
    Jan 2023
    6c0959655h b2000 HELP PLEASE
