Results 1 to 8 of 8
    golf110tdi's Avatar
    Apr 2016
    EU
    Default KESS V2 DSG dq250 unknown ecu hardware
    Hello friends. Yesterday I tried to read my gearbox DQ250 with my KESS v5.017 said the ''unknown ecu hardware''. I tried to read with ksuite 2.47 and 2.23 by OBD and on dsg plug but every time kess said ''unknown ecu hardware''.
    maybe is dq250 Fxx and kess wont work
    Kocta's Avatar
    Mar 2017
    Garage in the Czech Republic
    Vag can pro ori. - no problem
    Press Thanks and Reputation
    golf110tdi's Avatar
    Apr 2016
    EU
    How to solve the problem. My car is golf 6 2008, but mechatronics is made in 17.11.2016. Could this be a problem.
    golf110tdi's Avatar
    Apr 2016
    EU
    Hello everyone. I read my gearbox dq250 (golf 6 2.0tdi) with PCMflash. Now I wanna do some adjustments but, I dont know how to correct the checksum. In forums someone said don't need checksum correction, someone said the tools correct the checksum but I am sure that my tool cannot correct checksum.
    figani's Avatar
    Feb 2018
    47 45 52 4D 41 4E 59
    Quote Originally Posted by golf110tdi View Post
    PCMFlash correct through writing checksum in Flash...
    not in eeprom...
    When I help you press Thanks and Reputation...
  7. The Following User Says Thank You to figani For This Useful Post:
    golf110tdi (23rd May, 2019)
    golf110tdi's Avatar
    Apr 2016
    EU
    The seller told me that a PCMflash cannot correct the checksum on this file.
    If I write a modifica file without checksum, can make a restore with write back ori file.
    golf110tdi's Avatar
    Apr 2016
    EU
    Yes you are right. I tested it and everything was fine. I figured out how to activate launch control, but something did not work. Thank you for the reply.
