Results 1 to 13 of 13
    venceslau's Avatar
    Dec 2018
    North America
    Default PCF79XX unlock/renew? What device can do it?
    Hi, I'm looking to buy a clone device that can do PCF79XX unlock/renew to re-program OEM BMW fob.
    What device do you know that can do this? I am wondering if FVDI 2018 can do this since it comes with VVDI2 BMW software which has Unlock menu. Has anyone tested this?
    MK3 Master Key - unlock/renew PCF79xx Supported
    VVDI Key Tool - unlock/renew PCF79xx Supported
    VVDI Prog - read/write PCF79xx Supported
    FVDI 2018 - Supported or Not?
    Thanks in advance
    koolstuff's Avatar
    Nov 2015
    Dakar (Senegal)
    VVDI key tool can unlock BMW Oem and many OEM keys using wired connections. I have done many nissan and BMW keys.
  3. The Following User Says Thank You to koolstuff For This Useful Post:
    venceslau (5th February, 2019)
    venceslau's Avatar
    Dec 2018
    North America
    Quote Originally Posted by koolstuff View Post
    Thanks for confirming. Do you know if FVDI can do it as well? Cheers
    Sent from my A0001 using Tapatalk
    Quote Originally Posted by venceslau View Post
    fvdi can not
    Jan 2016
    Jumping Around the globe
    MK3 works, but its on the expensive side, and there is no development since long time. I think developpers dropped that tool
  7. The Following User Says Thank You to Locker For This Useful Post:
  8. #6
    Apr 2016
    uk
    Barracuda,pcf programmer,kd_x2,SOS unlocker,vvdi Key tool,biotech..
    Barracuda semms to be the best choice but also the most expensive..
  9. The Following User Says Thank You to comizelu For This Useful Post:
  10. #7
    Nov 2015
    VVDI Key Tool + Renew adapters = fast work
  11. The Following User Says Thank You to Adam871 For This Useful Post:
    venceslau (6th February, 2019)
  12. #8
    venceslau's Avatar
    Dec 2018
    North America
    OK, I like VVDI Key tool, seems to do what I need and is super easy to use.
    Can it also program CAS3+ keys?
  13. #9
    koolstuff's Avatar
    Nov 2015
    Dakar (Senegal)
    vvdi key tool can only read renew and test frequency of keys.
  14. #10
    Nov 2015
    + copy transponders and making universal remotes.
  15. #11
    venceslau's Avatar
    Dec 2018
    North America
    Quote Originally Posted by Adam871 View Post
    What are my options for dealing with CAS3+?
    I have xprog, ktag and hitag. I need some tool that comes with software to handle crypto side and ISN matching.
  16. #12
    Jan 2016
    romania
    Obd x300
    Trimis de pe al meu SM-J330F folosind Tapatalk
  17. #13
    Nov 2015
    Check VVDI2 with bmw authorizations
  18. The Following User Says Thank You to Adam871 For This Useful Post:
    venceslau (7th February, 2019)
