Page 1 of 3 123 LastLast
Results 1 to 15 of 39
    Jul 2013
    romania
    Default bcm vw passat b6 2011 dead with abritus clone,need help
    hello friends,need some help with bcm from vw passat cc 2011 year.... i try to add new key with abritus clone,..i read bcm by obd(big mistake),and after that the bcm its dead......i scan the car and i have comunication with bcm but error ..in all electronics modules(no comunication with bcm)...in the past i did key with the same abritus clone,but i thake the bcm down and read eeprom 95320 directly....
    i see in bcm the pin code and the vin number...,i think its partial dead.....the question its.......CA SOMOANE HELP ME TO REPAIR THIS FILLE FROM MY BCM??????????/ i will atac 95320 eeprom files...and atach eeprom files from another bcm from donnor car...maybe i will save my module....
    my original bcm its 3C0959433AR,and the donnor its 3C0959433AQ......
    please guys.......and dont use in the future abritus clone for doing the key in the obd method....
    Jul 2013
    romania
    the pin from original eeprom bcm its 53027-----=vin number WVWZZZ3CZBE726969 and from donnor bcm its 59180---vin number WVWZZZ3CZAE009525,please ceck that too..to see its corect...help me guys
    Aug 2015
    how did you read bcm (ccm) over obd? what option in FVDI ? i don't think it is possible with any, even original tool.... not sure tho...
    Jul 2013
    romania
    do you have solution for me?
    Jul 2013
    romania
    i try with option v24--iimo V----BCM2 IMMOBILIZE--select get old CS by obd---next,and after that.....DEAD!!!!!1
    topclef's Avatar
    Quote Originally Posted by cutiutza View Post
    BCM2 is for AUDI Q5 A4 A5 ......etc
    CCM is for Passat , even with AVDI Original you can't read CCM immo-data via OBDII
    you have two choices in the morning: go back to bed and continue dreaming, or you get up to make your dreams come true
  7. The Following User Says Thank You to topclef For This Useful Post:
    nenadgorgi (7th February, 2019)
    Jul 2013
    romania
    ok,my mistake...any solution to repair this?
    i try to modify some bits,,,i manage to start the car....but have errors in parkink brake,trailer...no comunication and remote control not working
    Jul 2013
    romania
    problem solved by myself......somthing get wrong in the eeprom 95320,i just modify 2 bits..and all ok...
  10. The Following User Says Thank You to cutiutza For This Useful Post:
  11. #9
    topclef's Avatar
    glad for you
    share your experience if you need help next time
  12. #10
    Denmark
    please give solution
  13. #11
    topclef's Avatar
    Quote Originally Posted by turboracing View Post
    he looking only help , for the sharing.....catch me if you can
  14. The Following 3 Users Say Thank You to topclef For This Useful Post:
    autochei (7th February, 2019), dijo (12th October, 2021), p1et (18th April, 2023)
  15. #12
    autochei's Avatar
    Mar 2013
    romania
    i think dump not starting corectly from beggining first 2 bits should be start with ff ff
  16. The Following 2 Users Say Thank You to autochei For This Useful Post:
    cole_mcs (20th September, 2024), nenadgorgi (8th February, 2019)
  17. #13
    Jul 2013
    romania
    i help all the members on the dk.....i you see in my fille eprom when you open the fille ..you will see that the first bits its 55 AA,,thats the eeror on the bcm....it was strange form me when i read the eeprom 95320,,,,after i put in the first bits FF FF...,the car starts with no errors ,no need coding enything... work like a charm..
    this is my experince ..and i share with you all....
    i hell anyoane for free if i can do that..in the future...if i help...with this info....just press thanks!!!!!!!!!!!!!!!!
  18. The Following 11 Users Say Thank You to cutiutza For This Useful Post:
    autodigitec (11th February, 2022), berciumihai (15th April, 2023), cole_mcs (20th September, 2024), Jobeso66 (10th February, 2019), leotdx (9th September, 2019), nenadgorgi (8th February, 2019), p1et (8th February, 2019), schouten1977 (9th February, 2019), tepSIJA (15th April, 2023), xseva (31st May, 2019)
  19. #14
    Jul 2013
    romania
    and topclef
    ...i just
    .catch..you!!!!!
  20. The Following 3 Users Say Thank You to cutiutza For This Useful Post:
    Jobeso66 (16th May, 2019), tepSIJA (15th April, 2023), topclef (10th February, 2019)
  21. #15
    Jul 2013
    romania
    i share my exepriece...so...no need to be so .............,if i need help...i ask,if you need help just ask.....this is the DK........ IN MY OPINION
  22. The Following User Says Thank You to cutiutza For This Useful Post:
