    Jun 2012
    Default Mini Cooper dash not showing mileage
    Hi I have car Mini Cooper 2001 year. Dash not showing miles on led screen, on speedo and odometer. In diagnostic not fault code and all dash test positive only without led test. It possible to someone try to change mileage and corrupt dash ?
    Mar 2017
    Johannesburg south Africa
    looks like a hardware failure. it may be a damaged lcd
    When you use the
    THANKS and REP Buttons
    it gives energy to help more
    Appreciation is the key
    Jun 2013
    EU
    Go to the rear of the car, look in the trunk near the rear right corner where the brake lights connect and check for water ingest there. Common fault in new gen minis.
    Yhoni's Avatar
    Jun 2014
    Somewhere in time...
    Quote Originally Posted by autoelek View Post
    Hello friend, were you able to solve the problem of your dash? How did you do it, please?
    Thanks.
    If my post has helped you, do not forget to click on the "THANKS" and "REPUTATION" button !!!
    I do not answer in private questions that can be solved in public.
    Europe
    This is a very common problem. LCD is simply dead. Picture of autoelec shows wrong gauge, mileage is shown in center if it has a center clock. But both LCDs are prone to failure. Just replace the LCD with a known good one inside cluster.
    Yhoni's Avatar
    Jun 2014
    Quote Originally Posted by tomvleeuwen View Post
    Thanks for the information tomvleeuwen, but I found this fault in the Mini dash.
    https://www.youtube.com/watch?v=0557BDVprMo
    Do you think it is more common to solve it by replacing the lcd screens?
    Thank.
