Results 1 to 7 of 7
    May 2017
    Default Audi A4 B8 J519 Component Protection
    Hi, ive an audi a4 here that came as a non starter, j519 module was water damaged so fitted a used replacement with same part numbers, now all codes are clear but component is in protection mode and stil no start, (fuel pump not priming). I dont want to take the car to audi, can i clone the old j519 onto the new one? i have vcp and vcds, or would it be possible to swap the eeproms on the boards?
    Rito's Avatar
    AVDI do some protection component in vag. But what module you refer j519??
    Oct 2015
    I think the best way for Component Protection is Odis online
    May 2017
    Quote Originally Posted by Rito View Post
    J519, module 09 central electrics
    Rito's Avatar
    Quote Originally Posted by Perryking View Post
    Odis not do it...
    To made component protection nee have file from gateway.
    Nov 2018
    P L
    Active Component Protection j519 (BCM1) in A4 B8;
    - dim counter light
    - no lighting inside the vehicle
    if the fuel pump is not working, it is not the fault of an active CP.
    and if you want to delete CP, you can rewrite the processor (Motorola on the motherboard - I do not remember what)
    Dec 2019
    Quote Originally Posted by yarowsc View Post
    - dim counter light
    I just bought a used audi a4 b8 2009 that was in a crash before, and now it has been facelifted to a b8.5 so it has gotten used parts such as headlights etc. and i have the exact problem you wrote before (dim counter lights,and no interior lights) is the problem caused by the cp? because everything else is working fine. Can i have someone to remove the component protection? how do you do it? i really need your help!
    Thanks!
