Results 1 to 14 of 14
    Aug 2018
    Default Peugeot 307 2.0L RFK - Immo off
    Hi Guys I have a 2004 Peugeot 307 which has lost key immobilizer memory. I think its because we removed the battery for a long time. I want immobilizer to be switched off. Ktag tells me that EEprom is not present on this magneti marrelli ecu (see attached photos). Does the file from the Micro ST10F296 contain immo data you need to turn it off?
    Anyone with experience of this car please advise
    robert1232's Avatar
    Dec 2010
    Ireland ;)
    starter is run???
    PRESS THANKS AND REPUTATIONS (STAR) BUTTON
    I don't give others the password to the file. I'll send my file and I'll try to make it
    Nov 2017
    Indonesia
    as far as i know, iaw6lp only have virgin solution and recode again with planet or diagbox
    try post your dump
    likely you can find pin in the dump
    then you can program bsi n key with this pin
    Aug 2018
    unfortunately i dont have a tool to read dump inside the BSI, I only have KTag to read ECU. I have diagnostic tool to do key programming but I have no idea where or how else to get security code. Any ideas?
    rafal's Avatar
    UK - PL
    read bsi...................
    need help
    now my goal is to buy xp-005
    who will help?
  6. The Following User Says Thank You to rafal For This Useful Post:
    brend (12th February, 2019)
    brend's Avatar
    Oct 2015
    Same where
    K-tag just can't read eeprom in this ecu.
    It's mean eeprom need read with another programmer.
    Quote Originally Posted by battleship7 View Post
  8. The Following User Says Thank You to brend For This Useful Post:
    rafal (13th February, 2019)
  9. #7
    Nov 2017
    Indonesia
    post your st10 dump
  10. #8
    No eeprom in this ECU but emulated eeprom ! Ktag states this clear on the image posted "NOT PRESENT", does not mean "can't read"
    Post 10F296 as said.
  11. #9
    brend's Avatar
    Oct 2015
    Same where
    So.....Mr.Zmann!!!
    This k-tag can or can't?
    Quote Originally Posted by Zmann View Post
  12. #10
    Quote Originally Posted by brend View Post
    So.....Mr.Zmann!!!
    On this family of ECU's there is no eeprom like 95xxx or 24cxxx, only emulated eeprom on 10F internal flash.
  13. #11
    Nov 2017
    Indonesia
    yes you are right
    i did many time in iaw6lp
    just read ST10 in boot mode
    ktg, mpps can do that
    virginize file if you wan to use in another car
    or take pin from the dump if you want to make key
  14. #12
    brend's Avatar
    Oct 2015
    Same where
    Yes for emulated eeprom you use another equpment not k-tag.With key-tag possible only full clon without separated emulated eeprom!
    So.....Mr.Zmann!!!
    K-tag can't to do all job if you want only eeprom!!
  15. #13
    So.....Mr.Zmann!!!
    You telling me ? Where did you see I asked to get eeprom from the dump ? No one will extract eeprom (emulated) from these kinds of ECU dumps. And if I really need such extracted eeprom I can do easily with any tool that is able to read 10Fxxx including K-tag.
    Seems you don't know what emulated eeprom in these ECU's is. If you want to learn I can show you where are those 8 repeated eeprom banks in these kinds of MM ECU's
    Regards,
  16. #14
    brend's Avatar
    Oct 2015
    Same where
    Regards,
    And all this discation,,,,,,,,,, if you have only k-tag''''''''''..............
    So........and all this keep you self.
