Results 1 to 8 of 8
    Aug 2016
    Default Seat leon 2007 dash pinout
    Hi inneed pinout for powering up leon dash . Appreciate it if someone can help.
  2. The Following User Says Thank You to garagetech007 For This Useful Post:
    dejhon (22nd October, 2024)
  3. #2
    bidu20's Avatar
    Jun 2016
    Stecker schwarz
    (Pin 1 - 18)
    1 Kl. 15
    2 Kl. 30
    3
    4
    5 Kontrollleuchte für Bremsflüssigkeits- stand
    6 Handbremse
    7 Lesespule für Wegfahrsperre / Transponder
    8 Lesespule für Wegfahrsperre / Transponder
    9
    10
    11
    12 CAN Low
    13 CAN High
    14 CAN Schirm
    15 CAN Weckleitung
    16 Tankgeber (4 Motion)
    17 Tankgeber / Tank voll
    18 Tankgeber / Tank leer
    Stecker schwarz
    (Pin 19 - 36)
    19 Kl. 31
    20
    21
    22 Bremsverschleiss
    23
    24 Kontrollleuchte Tankverschluss
    25 Öldruckschalter
    26 Geber für Ölstand und Öltemperatur
    27
    28 Geschwindigkeitssignal Ausgang
    29 Geschwindigkeitssignal Eingang
    30
    31
    32
    33 Kl. 31 Gebermasse
    34 Scheibenwaschwasserstand
    35 Kühlmittelmangel
    36 Temperaturfühler für Aussentemperatur
    here mate..
    Don't forget the magic button !
  4. The Following 8 Users Say Thank You to bidu20 For This Useful Post:
    alclot (17th February, 2019), castin (26th September, 2020), danielif (17th November, 2022), daquima (5th September, 2019), ernesto1670 (23rd February, 2019), ftc (5th November, 2021), jurlak1 (14th October, 2021), volodin69 (11th March, 2023)
  5. #3
    Nov 2018
    somebody have english version ?
  6. #4
    Nov 2017
    Dobruja
    Are you joking...
    Pin 1 Ignition 12V
    Pins 2, 31 permanent 12V
    Pin 12 CAN L
    Pin 13 CAN H
    Happy with this?
    Post edit:
    Pin 1 Ignition 12V
    Pins 2 permanent 12V
    Pin 12 CAN L
    Pin 13 CAN H
    Pin 19 Ground.
  7. The Following User Says Thank You to volodin69 For This Useful Post:
    rafal (11th March, 2023)
  8. #5
    Oct 2020
    Bulgaria
    Maybe he need full pinout. Are you sure that pin 31 is powered? You missed also GND at pin 19.
  9. The Following User Says Thank You to evgeny87 For This Useful Post:
  10. #6
    Nov 2017
    Dobruja
    Right. Sorry, i am using 1,2,12,13,19. 19 in German means 31 )))
    He needs full pinout for what? Does he connect it throuh a can gateway on the bench? Sorry for being mean, but Google can show you all pins if you REALLY want to search, insead of being lazy, or wait for someone's help...
  11. The Following User Says Thank You to volodin69 For This Useful Post:
    evgeny87 (12th March, 2023)
  12. #7
    Nov 2018
    ok,ok no need top be rude
    i found by myself,
    I was creating 32 pin connector adapter to 36 pin dash
  13. The Following User Says Thank You to vitz6 For This Useful Post:
  14. #8
    Nov 2017
    Dobruja
    32-pin connector, blue (Midline)
    1 - Terminal 30 -> +12V
    2 - Terminal 30 -> +12V
    3 - Terminal 31 -> GND
    4 - Terminal 31 -> GND
    5 - CAN Bus (diagnosis) wake-up wire -> PIN 13 GW
    6 - Fuel gauge sender 2, signal (quattro)
    7 - Brake pad
    8 - Oil level
    9 - Not used
    10 - Not used
    11 - Not used
    12 - Not used
    13 - Not used
    14 - Brake fluid low
    15 - Oil pressure switch
    16 - Not used
    17 - Terminal 58d
    18 - Terminal 30 -> +12V
    19 - Terminal 31 -> GND
    20 - Not used
    21 - Coolant level low
    22 - Not used
    23 - Not used
    24 - Ambient temperature
    25 - Fuel gauge sender 1, signal
    26 - Fuel gauge sender 2, overall resistance
    (quattro)
    27 - Fuel gauge sender 1, overall resistance
    28 - Sender earth
    29 - CAN bus diagnosis High
    30 - CAN bus diagnosis Low
    31 - Transponder Rx
    32 - Transponder Tx
    Pinout Gateway
    Pin 1 Terminal 30, fuse F24 in EM box -> +12V
    Pin 2 As pin 1 -> +12V
    Pin 3 Vacant
    Pin 4 K-wire (vacant)
    Pin 5 Convenience system data bus, CAN-Low
    Pin 6 Drive train data bus, CAN-Low
    Pin 7 Vacant
    Pin 8 Dash panel insert data bus, CAN-Low
    Pin 9 Diagnosis CAN, CAN-Low
    Pin 10 Infotainment data bus, CAN-Low
    Pin 11 Terminal 31 (battery negative) -> GND
    Pin 12 Terminal 31 (battery negative) -> GND
    Pin 13 Wake-up wire, dash panel insert -> PIN 5 DB
    Pin 14 Terminal 15 -> +12V
    Pin 15 Convenience system data bus, CAN-High
    Pin 16 Drive train data bus, CAN-High
    Pin 17 Vacant
    Pin 18 Dash panel insert data bus, CAN-High
    Pin 19 Diagnosis CAN, CAN-High
    Pin 20 Infotainment data bus, CAN-High
    36-pin connector -T36- :
    1 -Terminal 15 voltage supply
    2 -Terminal 30 voltage supply
    3 - Not assigned
    4 - Not assigned
    5 - Brake fluid level warning lamp
    6 - Warning lamp for electric parking brake and handbrake
    7 - Transponder coil1
    8 - Transponder coil2
    9 - Not assigned
    10 - Not assigned
    11 - Not assigned
    12 - Diagnostic interface for dash panel CAN data bus, low
    13 - Diagnostic interface for dash panel CAN data bus, high
    14 - Dash panel CAN screening
    15 - Dash panel CAN wake-up wire
    16 - Fuel gauge sender (full), only with all-wheel drive
    17 - Fuel gauge sender (full)
    18 - Fuel gauge sender (empty)
    19 - Terminal 31
    20 - Not assigned
    21 - Not assigned
    22 - Front left brake pad wear sender
    23 - Fuel gauge sender (empty), only with all-wheel drive
    24 - Not assigned
    25 - Oil pressure warning lamp
    26 - Oil level and oil temperature sender
    27 - Not assigned
    28 - Speed signal, sliding sunroof adjustment control unit output, control unit with display for radio and navigation system
    29 - Not assigned
    30 - Not assigned
    31 - Not assigned
    32 - Not assigned
    33 - Terminal 31, sensor earth
    34 - Washer fluid level warning lamp
    35 - Coolant temperature and coolant shortage warning lamp
    36 - Ambient temperature sensor
  15. The Following User Says Thank You to volodin69 For This Useful Post:
    budata (12th March, 2023)
