Results 1 to 7 of 7
    marcolr's Avatar
    Default Opel Corsa D 1.3 CDTI Full BDM Need
    Hi mates,
    I need a full BDM read of a Magnetti Marelli
    55568383KZ
    MJD 6O3.S3/HW03A/3333-S362
    S4400 Z13DTJ MT
    The problem is that the original ecu is water damaged and all data inside of Mpc is FF.
    I get a used ecu with same HW number, but sw is 3137-S360 and if I reset ecu and adapt it to the car, the car starts but P060B (change ecu) come and the engine is limit to 1500rpm.
    I canīt clone with original data because I donīt have the original Mpc data.
    Itīs very important the sw 3333-S362
    Thanks in advance
    If my post was helpful press Thanks button!!
    UK
    Im sure I have this data, will try to find it for you. In meantime do you have global tis? If you do then sps programming should be able to help you.
    if this post was usefull
    please press
    the thanks button
  3. The Following User Says Thank You to looly For This Useful Post:
    Benwilson (3rd March, 2020)
    marcolr's Avatar
    I donīt have global tis, but I try just now with data of a Meriva with same hw number and sw 3333S381. Write full bmd, reset ecu, program immo and by the moment seems to be ok. The P060B disappeared and the engine rpm are not limited now. Tomorrow Iīll try the car on the road and see what happens.
    But if you have full bdm with 3333S362 I apreciate if you can upload it.
    Sapuhin's Avatar
    Feb 2017
    PL"Poland"
    Hi mates,
    I need a full BDM read of a KTAG
    55568383KZ
    S4400 Z13DTJ MT
    Thanks in advance
    If I helped you - please press Thanks and REP.
    72 61 69 73 65 20 74 68 65 20 72 61 74 69 6E 67 20 69 66 20 68 65 6C 70 65 64
    I will help with all I can. Open for help 24/7 (Find software, dump, kick in the right direction)
    TECHSIX.NET - PLEASE BE CAREFUL THIS SCAMMER !!!!
  6. The Following User Says Thank You to Sapuhin For This Useful Post:
    peke205 (12th March, 2023)
    marcolr's Avatar
    Quote Originally Posted by Sapuhin View Post
    Hi mates,
    55568383KZ
    S4400 Z13DTJ MT
    Thanks in advance
    Hi mate. Here is your files.
    I read it with BDM100, but I uploaded 4 files for you (All, Mpc, Flash and Eeprom), then you can use it with Ktag.
  8. The Following 7 Users Say Thank You to marcolr For This Useful Post:
    AndreyAtr (4th September, 2021), athas (14th January, 2025), Jexus86 (23rd December, 2024), peke205 (12th March, 2023), putodaserra (14th February, 2022), Sapuhin (8th January, 2021)
  9. #6
    Sapuhin's Avatar
    Feb 2017
    PL"Poland"
    Quote Originally Posted by marcolr View Post
    Thanks, can there be full BDM KTAG 3333S381?
  10. #7
    marcolr's Avatar
    The same as before. Data was read with BMD100.
  11. The Following User Says Thank You to marcolr For This Useful Post:
