Results 1 to 8 of 8
    Default Suzuki Panasonic car radio
    Could anyone help me with code, please?
    Model no. CQ-JZ93F3TT
    Ref 39101-84M50
    ID no. 76MO
    Serial no. 502226
    memory 24c08. Damp is attached.
    Thanks in advance.
    ZoX
    Oct 2013
    Ukraine
    Quote Originally Posted by zorans View Post
    Ref 39101-84M50
    ID no. 76MO
    Serial no. 502226
    Thanks in advance.
    ZoX
    Hi.
    try...........5159 or 9515
  3. The Following 2 Users Say Thank You to masterskay62 For This Useful Post:
    Kriootron (20th September, 2022), petronijul (22nd February, 2019)
    Yes, I would like to try, but now I have on display "EEPROM ERROR". I again checked eeprom, reading ok, put back on pcb, everything is ok but on display "EERPOM ERROR". Whats now!?
    Oct 2013
    Ukraine
    Check the elements around the eeprom.
    Already checked. Found two pull-up resistors broken on SDA and SCL pins. But again same error. I am still looking
    Apr 2016
    HI I HAVE THE SAME RADIO AND DECODED THE EEPROM AND RESOLDERED TO BOARD AND NOW GOT (EEPROM ERROR) ANY IDEAS ANYONE
    THANK YOU
    Taras+'s Avatar
    Bonbaden
    You need to become a data bus oscillograph and see if data exchange. It is quite possible that the percent does not see eeprom and lets you know about it.
    61 C4 0E A8
    Apr 2011
    Hi mate.
    Check small smd resistor coming from pin 5, these are easy to dislodge.
    Regards,
    Jules.
