Results 1 to 4 of 4
    Oct 2016
    Default renault kagoo 1.5dci 2012 dtc off p0002 ,p0087
    Hello colleagues I need dtc off these dtc P0002, P0087 I have problems with this car
    renault kagoo 1.5 dci year 2012
    ecu: dcm 3.4
    thanks and regards
    Jun 2013
    Lithuania
    ... P0087 is for low fuel pressure (also P0002 is set because system cannot maintain required fuel pressure...), you won't fix, or DTC removal won't help... Check/Replace fuel filter, do injector return leak test, and alot of chances that this "Delphi" pump is damaged, worn out Had few of these with same problem, pump is worn out, also metal bits from pump damage injectors
  3. The Following User Says Thank You to Milicija For This Useful Post:
    garagesport (24th February, 2019)
    Oct 2016
    ya mate this all revised I just want to eliminate these dtc can help dtc off
    Hello everyone
    p0087
    I think there is something to do with canclip
    but I do not know, to see with the specialists of renault
    good luck
