Howdy all,
Just wondering if anyone can help me with a 6 digit radio code for a 1998 C200 Mercedes with eurovox 8790
it's VIN is;wdb2020202f706169
Model no.;8790
Serial no.;322008048.8.
Thanks in advance
Howdy all,
Model no.;8790
Thanks in advance
Here's both sides of the resistor code board for the radio in question if it helps....
Hi.
Try..........
Can you put a photo with the sticker taped on the radio? It seems the serial is not good.
sorry but there isn't a 6 digit cod there?
that was a direct copy of serial off sticker but cant post it for 12hours from now when I get back to workshop!
Does that change it from 6 digit code to 4 digit code?
I'm guessing there isn't a 6 digit solution out there?
so I removed that 1 resistor & tried that code, but it still want's a 6 digit number entered so 5341 wont work?
Hi try to unsolder 1 pin of all diode and see
Maybe working without code.
o.k. so I found a 6digit code matrix board image that's know so if they attached layout's code is 325422 what would that make the code for my original & now the modified board?
So if you can confirm that 6 digit code why can't you confirm my original or the other you told me to modify as the 4 digit code for it cant be done?
