Results 1 to 5 of 5
    sdnatlst's Avatar
    Aug 2011
    England
    Default honda HRV 2002 - all keys lost help
    hi all
    got a honda HRV 2002 all keys lost
    Lonsdor wont communicate
    MVP pro goes through programming OK, but at last stage says "is immo light off", when i click NO, because key still flashing, it says ERROR FAILED.
    i tried battery reset, i tried MVP pro again and just said YES to light off, still wont start on the key.
    It is ID48 megamos
    I removed the small box near ignition coil thinking it is immo but think it is just coil / immo antenna power box.
    How can i do AKL on this car?? THANKS
    Top Poster dooshan's Avatar
    Mar 2012
    Belgrade
    That small box is Honda immobox. 93c46 on downside. Image file will start the car.
    sdnatlst's Avatar
    Aug 2011
    England
    Quote Originally Posted by dooshan View Post
    thanks, i thought that too, but i dont think its right, i think it has seperate immo box, this is what i have removed -
    Immobiliser Antenna / Sensor (ab02229t) - Honda Accord
    see photo, i think its just an antenna power box.
    if i search HRV immoboliser, i get a larger grey immobiliser unit, maybe somewhere else on the car?
    autochei's Avatar
    Mar 2013
    romania
    use sbb very easi
    sdnatlst's Avatar
    Aug 2011
    England
    not got SBB, MVP pro also should very easy,,, unfortunatly not with this car,,, i am trying ID48 megamos, im sure its right.
    but if look here, this seems like immobliser for this car, not on the ring
    https://www.ebay.co.uk/itm/Immobilis...1IVG:rk:3:pf:0
