hi how to clear crash this ecu 2Q1909144J, VCDS AND VCP don t work , mcu is sak-tc234lp , maybe only vas or odis onlline, DTC P160900
Hi . I had the same problem. I found solution in this tread.
https://forums.ross-tech.com/showthr...ll=1#post79196
You must EPS "restore to factory setting" with VCDS and then calibrate everyhing.
don t work this car , login and factory seeting dont worked
you do this with vcds
PRESS THANKS AND REPUTATIONS (STAR) BUTTON
I don't give others the password to the file. I'll send my file and I'll try to make it
Any solution? I have same problem with same ecu
did anyone solve this problem? I have the same thing in Ibiza 2017. , Power Sterring 2Q1909144J.
I have solution to be used with launch
access login will cost but I can get you code if you need
44. steering assistance (red steering wheel light on dash)
code crash input or similar
enter access permission code, reset factory settings.
no fault, red light still on dash.
disconnect battery for 10-15 mins.
switch car on power steering should be restored!!!
br
slick
“There's nothing more dangerous than someone who wants to make the world a better place.” ― Banksy
send info PM
I can write yes;
in my case nothing helped, the problem was not solved.
Ibiza 2018year, 2Q1909144J, reflash Odis Online, online parameterization, next reset to factory settings - no changes, sterring does not work, the error is still saved. I also tried to flash VCP, Odis engineered files;
- 2Q1909144J_6030_V001
- 2Q1909144ZU_BOOT_V001
- 2Q1909144ZX_BPLD_V001
- 2Q1909144ZX_BPLD_V002
and nothing. power steering, if it didn't work, it didn't work
some say that Odis Online is the way to go. how ??
I am asking for tips as needed - I will pay.
Hi friend
I had a similar problem with a seat.
I've tried to clear the fault code with vag-com, but it didn't work.
By texa diagostic I've redefined all adaptations and auto-adaptation (reset factory values)
After turning off the ignition the error desappeared (I don't know how, but...)
Hope this could help you
Best regards
Pinheiro
redefining all adaptations
have someone pinout for Jtag or Boot for this unit ?
Its One MCU PCB
Regards,
Boras
i can do it
Need odis engineering
